Ethernet Products
5659 Discusiones
big troubles with Intel 82574L
KKrei
Principiante
3.001 Vistas
Hi guys,
I do have a motherboard based on the Intel C206 chipset which us used with an Intel Xeon E3-1260L processor. The board does have two Gb Intel NICs, one being an Intel 82574L (07:00.0) and the other being an Intel 82579LM (00:19.0); both numbers in paranthesis from lspic on linux - full details from lspci as follows (the two NICs are in bold and marked by ==>):
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:01.1 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 Processor Family Integrated Graphics Controller (rev 09)
00:06.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller # 1 (rev 04)
==> 00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (rev 05)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller # 2 (rev 05)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b5)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b5)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller # 1 (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation C206 Chipset Family LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
01:00.0 Serial Attached SCSI controller: LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 02)
02:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 01)
03:00.0 Unassigned class [ff00]: OpenVox Communication Co. Ltd. Device 0100 (rev 01)
04:00.0 Network controller: Qualcomm Atheros AR93xx Wireless Network Adapter (rev 01)
05:00.0 PCI bridge: PLX Technology, Inc. PEX8112 x1 Lane PCI Express-to-PCI Bridge (rev aa)
06:00.0 Communication controller: OpenVox Communication Co. Ltd. Device 0810 (rev 14)
==> 07:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
08:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03)
09:00.0 PCI bridge: Pericom Semiconductor PI7C8148A/PI7C8148B PCI-to-PCI Bridge
0a:08.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
0a:09.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
0a:0a.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
0a:0b.0 Network controller: Qualcomm Atheros AR922X Wireless Network Adapter (rev 01)
Already at the beginning there have been issues with one of the onboard NICs: Although according to the board's MAC-address sticker its MAC address should have been 00:18:7d:1d:72:74 it actually identified with 88:88:88:88:87:88 to my DHCP server. The board manufacturer then sent me a firmware update tool and advised me to update the MAC adress - which I did.
Subsequentyl I faced substantial issues trying to bond the two NICs together which resulted in packet loss and very instable connections (e.g. long delays in ssh before a response came). As I was not sure whether I did something wrong, I decided to change plan und only use one NIC - according to lspci it was the 82579LM on address 00:19.0 - for my dom0 (the system will be used under XEN) and pass the second one through to a virtual HVM domu machine. After the XEN system was up and configured with a number of PV domUs I started to install the HVM domu and passed through the second.
Then the fun started again: Pinging the dom0 from the domu resulted in duplicate packets. There were NO duplicate packets when pinged from a Win7 machine so my first idea was that there's something wrong with the PCI-passthrough or linux. After thorough investigation it however turned out that the dom0 actually really sent two ICMP echo replie...
0 kudos
2 Respuestas
TMakk
Principiante
1.454 Vistas
Hi KK,
Did you manage to fix the problem with 82574L? Which of those two settings are from 82574?
Tony
TMakk
Principiante
1.454 Vistas
I found the answer to the second question . 7D1D71DE.EEP is from 82574l.
Responder
