Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
907 Discussions
epct64e Error "Cannot initialize adapter"
blacksky
Dear experts
I would like to reconfigure port modes of my network card and receive the following error from epct64e tool:
root@black:/home/cygent/proadmin/TOOLS/EPCT/Linux_x64# ./epct64e -devices
Ethernet Port Configuration Tool
EPCT version: v1.40.05.05
Copyright 2019 - 2023 Intel Corporation.
Cannot initialize port: [00:002:00:00] Intel(R) Ethernet Network Adapter E810-C-Q2
Cannot initialize port: [00:002:00:01] Intel(R) Ethernet Network Adapter E810-C-Q2
Cannot initialize port: [00:102:00:00] Intel(R) Ethernet Network Adapter E810-XXV-2
Cannot initialize port: [00:102:00:01] Intel(R) Ethernet Network Adapter E810-XXV-2
NIC Seg:Bus:Fun Ven-Dev Connector Ports Speed Quads Lanes per PF
1) 000:001:00-01 8086-1583 QSFP 2 40 Gbps - -
Error: Cannot initialize adapter.
Would appreciate your hint on how to troubleshoot the error. I have updated all drivers and OS and cannot come to a resolution after two days of searching and troubleshooting.
MY SETUP:
*** Intel E810-CAM2 network card from FS.com
*** ethtool -i enp2s0f0 output:
sudo ethtool -i enp2s0f0
driver: ice
version: 6.1.0-17-amd64
firmware-version: 4.40 0x8001c967 1.3534.0
expansion-rom-version:
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
*** Ethernet Port Configuration Tool v1.40.5.5
*** Debian 12.4
*** kernel 6.1.0-17-amd64
IntelSupport
Community Manager
Hi blacksky,
Can you please provide us with more information:
1. Please provide the output of "lspci" or "ifconfig"
2. Are you running the EPCT tool using sudo/ as a superuser?
3. Can you please confirm if the EPCT tool is the latest version and are compatible with the E810-CAM2 version?
4. Have you tried reseating the adapters?
5. Kindly provide us with the "dmesg" output
6. Please let us know if it worked previously and what changed?
Hayat
Intel Customer Support
blacksky
Dear Hayat
thank you for your support! Herewith the information requested:
1. lspci output:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14d8
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 14d9
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14db
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14da
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14dd
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14dd
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e7
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-C for QSFP (rev 02)
02:00.1 Ethernet controller: Intel Corporation Ethernet Controller E810-C for QSFP (rev 02)
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f4 (rev 01)
04:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
04:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
04:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
04:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
06:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f4 (rev 01)
07:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:0c.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
07:0d.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43f5 (rev 01)
08:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 03)
09:00.0 Ethernet controller: Aquantia Corp. AQC113CS NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 03)
0b:00.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0c:00.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0c:01.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0c:02.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0c:03.0 PCI bridge: Intel Corporation Thunderbolt 4 Bridge [Maple Ridge 4C 2020] (rev 02)
0d:00.0 USB controller: Intel Corporation Thunderbolt 4 NHI [Maple Ridge 4C 2020]
39:00.0 USB controller: Intel Corporation Thunderbolt 4 USB Controller [Maple Ridge 4C 2020]
66:00.0 Ethernet controller: Intel Corporation Ethernet Controller E810-XXV for SFP (rev 02)
66:00.1 Ethernet controller: Intel Corporation Ethernet Controller E810-XXV for SFP (rev 02)
67:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43f7 (rev 01)
68:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43f6 (rev 01)
69:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43f7 (rev 01)
6a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43f6 (rev 01)
6b:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. KC3000/Renegade NVMe SSD (rev 01)
6c:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Raphael (rev c4)
6c:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] VanGogh PSP/CCP
6c:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b6
6c:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b7
6d:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b8
2. I'm running the EPCT tool using the super user.
3. I confirm that I'm using the latest EPCT tool version (currently Version: 1.40.5.5). This version is compatible with the E810-CAM2 network card (I downloaded it from Intel download side for 800 Series Network Adapters (up to 100GbE), Linux OS) and the older version of EPCT did work with these cards, when they had NVM v3.10.
4. I have tried to reseat the adapters without any effect.
5. dmesg output attached to my reply
6. I have run the NVM upgrade from v3.10 to v4.40 (with nvmupdate64e output "All operations completed successfully")
IntelSupport
Community Manager
Hello blacksky,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank you.
Hayat
Intel® Customer Support
blacksky
Hallo Hayat
my reply below disappeared from my thread (but I still have a copy of it in my mails).
Dear Hayat
1. lspci output:
3. I confirm that I'm using the latest EPCT tool version (currently Version: 1.40.5.5). This version is compatible with the E810-CAM2 network card (I downloaded it from Intel download side for 800 Series Network Adapters (up to 100GbE), Linux OS) and the older version of EPCT did work with these cards.
IntelSupport
Community Manager
Hello blacksky,
Thank you for your response.
We will be needing more information to check on this.
Can you provide us below information please:
1. SSU Logs - please refer the Help Guide for the Intel® System Support Utility
2. Can you please provide us the front and back picture of the adapter.
3. Can you please update on your system build and model.
4. Can you update if the adapter is prebuilt or bought separately.
Hayat
blacksky
Dear Hayat
herewith the info:
1. ssu log attached
2. pictures attached
3. ASUS ProArt X670E-CREATOR WIFI
4. adapter is bought separately
Thank you for your support!
CarlosAM_INTEL
Hello, @blacksky:
Based on the received information, you should address your consultations stated in this forum to the third-party manufacturers of the devices related to the reported situation as a reference to the channels listed on the following websites:
https://www.fs.com/tech_support.html
https://www.asus.com/us/support/contact/troubleshooting
@CarlosAM_INTEL.
IntelSupport
Community Manager
Hello blacksky,
Thank you for the information.
We are currently checking further with the engineering team.
Kindly give us some time and we will get back with more updates.
Hayat
IntelSupport
Community Manager
Hello blacksky,
Upon checking, we highly advised that for any inquiries related to Programming or Embedded Products, please post a question on Embedded Connectivity Community forum.
Please confirm the closure of this thread once you have posted in the Embedded Connectivity Community Forum.
Thank You
Hayat
IntelSupport
Community Manager
Hello blacksky,
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
