- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I have two custom ARM i.MX6 I210 systems, A and B.
System A works fine, establishes link and passes the loopback/offline test.
System B brings up the ethernet interface but never establishes link (100 or 1Gbit), and the loopback/offline test fails:
ethtool --test eth1
The test result is FAIL
The test extra info:
Register test (offline) 0
Eeprom test (offline) 0
Interrupt test (offline) 0
Loopback test (offline) 13
Link test (on/offline) 1
System A has an I210 (WGI210AT) connected over PCIe to the i.MX6. It uses the built-in phy and runs Kernel 3.0.35 and IGB driver 5.0.6. It has INVM image 'Copper NoAPM v0.6'.
System B has an I210 (WGI210AT) connected over PCIe to the i.MX6. It uses the built-in phy and runs Kernel 3.14.79 and IGB driver 5.0.5-k. It has INVM image 'Copper NoAPM v0.6'
This failure occurs with or without magnetics connected.
Could anyone suggest what might cause this type of failure? I believe that PCI communications with the I210 is ok given that the driver can communicate with the part. I have tested multiple instances of system B and all fail in the same way, so I don't believe the I210 is faulty.
Simon
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Our engineers have found the answer. The I210 internal phy isn't being powered because we neglected to connect 1V5 to pin 56 VDD1p5.
Hopefully this will help anyone who has a similar problem.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi SimonR1,
Thank you very much for sharing the information, a great help indeed.
Rgds,
wb
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
