Ethernet Products
5657 Discussions
i210 same MAC on different VLANs
GKoro
Hi.
Is it possible to change mac address on virtual NICs associated with VLANs created under Windows 10 using last Intel drivers for i210?
I cant find the way to do it.
Hi grinux,
Thank you for the post. I need to check on this, are you using an onboard I210 or I210-T1 standalone network adapter?
thanks,
wb
GKoro
Hi and thanks for answer.
I use onboard i210 but schematic is the same as i210-t1.
Grigory
Hi Grigory,
Thank you for the reply. Two things I need to check, but before that I need to inform you Currently VLAN is not supported in Windows 10, you may refer to the driver download site below for reference:
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=68668
"Creating Intel ANS teams and VLANs on Windows® 10 is currently not supported. As a result, when created, teams and VLANs do not pass traffic. We expect that ANS will be supported on Windows 10 client in a future release."
1) Just want to double check if you have configure the VLAN via any workaround already?
2) Or just want to know if possible to change the MAC address in VLAN in Windows 10 in case the VLAN is supported in Windows 10.
wb
GKoro
Hello.
I'm sorry for mistake. I use Windows 8.1 embedded.
Hi Grigory,
Thank you for the clarification. Let me check on this.
rgds,
wb
Hi Grigory,
Good day. Further checking the available option to change the mac is through the main network adapter , not on the VLAN adapter.
wb
GKoro
Hi.
I dont clearly understand. I need different MACs on different VLANs. Is it possible?
If i change MAC on main adapter it changed on VLANs too of course.
Hi Grigory,
Thank you for the feedback. Let me verify this.
wb
Hi Grigory,
Good day. So far that option is not available, is it possible you can share more details on why you need to change the MAC?
thanks,
wb
Hi Grigory,
Please feel free to provide the additional information why you need to change the MAC?
rgds,
wb
GKoro
Hi
In my application i need four VLANs with different MACs.
Realtek RTL8111 can do that for me easily.
Why i need different MACs.
In my application i210 connected to L2 switch back to back. Four physical ports routed from L2 switch to four RJ45 LAN connectors. VLANs using to help L2 switch to identify and isolate traffic from 4 virtual adapters in Windows and forward it correctly to each physical RJ45 ports. Also after forwarding L2 switch untag all the packets and all packets on four physical pors presents without VLANs. But with same mac addresses in my case.
All of components: cpu(E3845), i210 and L2 switch located on single PCB.
As mentioned above realtek allow me to get untaged packets with different macs on each physical connetor respectively because realtek allow to set any MAC address on their VLAN associated virtual adapters.
Grigory.
Hi Grigory,
Thank you for the information. I will have to further check.
wb
Hi Grigory,
Good day. Just to double check how are you setting the MAC address for the REALTEK adapters?
As I210 is an onboard NIC. Have you tried drivers supplied by the OEM?
There might be features in the OEM drivers to enable, have you tried contacted the OEM?
There are other tools that can change MAC address, you can try search online. Moreover, there is also a way to change this in the registry that can be obtained with a quick google search.
e.g. in the registry path below:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002bE10318}
Locate the key that contains "Intel(R) Advanced Network Sevices Virtual Adapter", inside that key there's "NetworkAddress, Type = REG_SZ" for the mac address.
Please feel free to update me.
Rgds,
wb
GKoro
Hi.
My company is OEM.
I tried drivers from public intel site and also from the https://businessportal.intel.com https://businessportal.intel.com. Result is the same.
I aslo tried registry trick you described above before post this topic and its not working. VLANs MACs is always same as root adapter MAC.
Hi Grigory,
Thank you for the update. I will further check.
Rgds,
wb
Hi Grigory,
Good day. Understand your company is the OEM, can you double check with system manufacturer for customized driver that may enable this capability.
wb
GKoro
Hi.
I have contacts of local Intel FAE and local sales representative. Should i contact them?
Hi Grigory,
Let me check first. I will update you when confirm.
wb
Hi Grigory,
Please contact your Intel FAE or sales representative as your company is an OEM company.
Rgds,
wb
