Ethernet Products
4633 Discussions
i350 10BASE-T interoperability
CKaly1
I have an i350 NIC (10/100/1000BASE-T port) connected to another node with a Broadcom BCM54640E PHY. Everything works fine in 100BASE-TX and 1000BASE-T modes. However, in 10BASE-T, no traffic goes through even though the link comes up. Packet counters in the BCM device indicate that it is sending packets, but the RX counters on the i350 NIC indicate no packets received. The same BCM device is able to interoperate at 10BASE-T with other nodes with Broadcom and Marvell PHYs, as well as an i210-based node. Any tips to debug this urgent issue are highly appreciated. Some details about the NIC below:
gigatest@ubuntu-SYS-2028R-TXR:~$ lspci -s 84:00.3 -xxx -vvvv
84:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
       Subsystem: Super Micro Computer Inc I350 Gigabit Network Connection
       Physical Slot: 26
       Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
       Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
       Latency: 0, Cache Line Size: 32 bytes
       Interrupt: pin D routed to IRQ 274
       Region 0: Memory at fa100000 (32-bit, non-prefetchable) [size=1M]
       Region 2: I/O ports at c000 [size=32]
       Region 3: Memory at fa700000 (32-bit, non-prefetchable) [size=16K]
       Expansion ROM at fa500000 [disabled] [size=512K]
       Capabilities: <access denied>
       Kernel driver in use: igb
       Kernel modules: igb
00: 86 80 21 15 07 05 10 00 01 00 00 02 08 00 80 00
10: 00 00 10 fa 00 00 00 00 01 c0 00 00 00 00 70 fa
20: 00 00 00 00 00 00 00 00 00 00 00 00 d9 15 00 00
30: 00 00 50 fa 40 00 00 00 00 00 00 00 0b 04 00 00
gigatest@ubuntu-SYS-2028R-TXR:~$ modinfo igb
filename:      /lib/modules/4.4.0-170-generic/kernel/drivers/net/ethernet/intel/igb/igb.ko
version:       5.3.0-k
license:       GPL
description:   Intel(R) Gigabit Ethernet Network Driver
author:        Intel Corporation, <e1000-devel@lists.sourceforge.net>
srcversion:    1D0A2836FEB6FDAA0BF834F
Crisselle_Intel
Hello CKaly1,
Please provide the following information as this would help us in checking your query.
1.) Are you using an embedded controller or PCIe card? If PCIe card, please share the PBA and serial number of the adapter for us to be able to identify the exact model of your card. You may refer to the link below on where to find the PBA number. You may also provide photos of the adapters focusing on the markings (white sticker) found on the physical card for us to double check on it. The PBA is consist of 6-digit number located at the last part of the serial number.
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
2.) Exact Operating system used
3.) Have you already tried the latest generic driver from Intel website below?
https://downloadcenter.intel.com/download/13663/Intel-Network-Adapter-Driver-for-82575-6-82580-I350-and-I210-211-Based-Gigabit-Network-Connections-for-Linux-?product=59679
We look forward to your response.
In case we don't hear from you, we will follow up after 3 business days.
Crisselle Franz
Intel Customer Support
Crisselle_Intel
Hello CKaly1,
Good day!
We'd like to follow up the requested information for us to proceed checking on your request.
Awaiting to your reply.
Crisselle Franz
CKaly1
Thanks Crisselle. It is a PCIe NIC card but right now we are not in a position to provide an image of the adapter since we are working from home and accessing the device remotely. Also, since it is a shared device it is not easy to update the driver. We will wait for an appropriate time when we an update the driver without impacting other folks. Also, with our debug so far has narrowed the issue down to some peculiar behavior in the Broadcom device at 10BASE-T and we are investigating that with Broadcom’s help. I will get back if we need additional help from Intel.
Crisselle_Intel
Hello CKaly1,
Thank you for the update.
Since you are already investigating the issue with Broadcom, we will be closing this request temporarily. If in case you will be needing our help on this matter, please do no hesitate to let us know and we will be more than glad to assist you.
May you have an amazing day ahead!
Crisselle Franz
