Ethernet Products
5736 Discussions
iANS VLANs seems to break Powershell "NetAdapter" commands, with "The data is invalid".
bilalu
I've a I210-T1 following a bit of a saga of finding an adapter for Windows 10 that can do VLANS....
I find that I can't manage any Windows network adapter using PowerShell's NetAdapter commands while there are any VLANs defined with this adapter.
Bit of a blow. Especially when certain changes in Windows (I think there was an update or a network reconfig courtesy of Hyper-V) cause all the VLAN interfaces to drop (and then you can't add them back with the same name because they're still floating around somewhere - full network reset fixes it - painful). Does this problem needs it's own "Ask"?
Mildly redacted example below.
PS C:\WINDOWS\system32> Get-NetAdapter   Name InterfaceDescription ifIndex Status MacAddress LinkSpeed ---- -------------------- ------- ------ ---------- --------- bluetooth Bluetooth Device (Personal Area Netw... 38 Disconnected XX-YY-ZZ-AA-BB-CC 3 Mbps ethernet-main Killer E2400 Gigabit Ethernet Contro... 39 Up XX-YY-ZZ-AA-BB-CC 1 Gbps ethernet-intel-parent Intel(R) Ethernet Server Adapter I21... 40 Disconnected XX-YY-ZZ-AA-BB-CC 0 bps wifi Qualcomm QCA9377 802.11ac Wireless A... 5 Disconnected XX-YY-ZZ-AA-BB-CC 0 bps       PS C:\WINDOWS\system32> Add-IntelNetVLAN -VLANID 17 -ParentName "Intel(R) Ethernet Server Adapter I210-T1"   VLANID VLANName ParentName ------ -------- ---------- 17 VLAN17 Intel(R) Ethernet Server Adapter I210-T1       PS C:\WINDOWS\system32> Get-NetAdapter Get-NetAdapter : The data is invalid. At line:1 char:1 + Get-NetAdapter + ~~~~~~~~~~~~~~ + CategoryInfo : InvalidData: (MSFT_NetAdapter:ROOT/StandardCimv2/MSFT_NetAdapter) [Get-NetAdapter], CimException + FullyQualifiedErrorId : Windows System Error 13,Get-NetAdapter   PS C:\WINDOWS\system32> Get-IntelNetVLAN | Remove-IntelNetVLAN   PS C:\WINDOWS\system32> Get-NetAdapter   Name InterfaceDescription ifIndex Status MacAddress LinkSpeed ---- -------------------- ------- ------ ---------- --------- bluetooth Bluetooth Device (Personal Area Netw... 38 Disconnected XX-YY-ZZ-AA-BB-CC 3 Mbps ethernet-main Killer E2400 Gigabit Ethernet Contro... 39 Up XX-YY-ZZ-AA-BB-CC 1 Gbps ethernet-intel-parent Intel(R) Ethernet Server Adapter I21... 40 Disconnected XX-YY-ZZ-AA-BB-CC 0 bps wifi Qualcomm QCA9377 802.11ac Wireless A... 5 Disconnected XX-YY-ZZ-AA-BB-CC 0 bps       PS C:\WINDOWS\system32>
Even commands that directly target unrelated network adapters fail:
PS C:\WINDOWS\system32> Get-NetAdapterBinding -Name ethernet-main   Name DisplayName ComponentID Enabled ---- ----------- ----------- ------- ethernet-main Microsoft Network Adapter Multiplexor Protocol ms_implat False ethernet-main QoS Packet Scheduler ms_pacer True ethernet-main Internet Protocol Version 4 (TCP/IPv4) ms_tcpip True ethernet-main Client for Microsoft Networks ms_msclient True ethernet-main Intel(R) Advanced Network Services Protocol iANSProtocol False ethernet-main Microsoft LLDP Protocol Driver ms_lldp True ethernet-main Hyper-V Extensible Virtual Switch vms_pp False ethernet-main Link-Layer Topology Discovery Mapper I/O Driver ms_lltdio True ethernet-main File and Printer Sharing for Microsoft Networks ms_server True ethernet-main Internet Protocol Version 6 (TCP/IPv6) ms_tcpip6 True ethernet-main Win10Pcap Packet Capture Driver Win10Pcap True ethernet-main Link-Layer Topology Discovery Responder ms_rspndr True ethernet-main Npcap Packet Driver (NPCAP) INSECURE_NPCAP True ethernet-main Npcap Packet Driver (NPCAP) (Wi-Fi) INSECURE_NPCAP_WIFI True ethernet-main VirtualBox NDIS6 Bridged Networking Driver oracle_VBoxNetLwf True ethernet-main Bridge Driver ms_l2bridge True       PS C:\WINDOWS\system32> Add-IntelNetVLAN -VLANID 17 -ParentName "Intel(R) Ethernet Server Adapter I210-T1"   VLANID VLANName ParentName ------ -------- ---------- 17 VLAN17 Intel(R) Ethernet Server Adapter I210-T1       PS C:\WINDOWS\system32> Get-NetAdapterBinding -Name ethernet-main Get-NetAdapterBinding : The data is invalid. At line:1 char:1 + Get-NetAdapterBinding -Name ethernet-main + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : InvalidData: (MSFT_NetAdapterBindingSettingData:ROOT/StandardCi...dingSettingData) [Get-NetAdapterBinding], CimException + FullyQualifiedErrorId : Windows System Error 13,Get-NetAdapterBinding   PS C:\WINDOWS\system32> Get-IntelNetVLAN | Remove-IntelNetVLAN   PS C:\WINDOWS\system32> Get-NetAdapterBinding -Name ethernet-main   Name DisplayName ComponentID Enabled ---- ----------- ----------- ------- ethernet-main Microsoft Network Adapter Multiplexor Protocol ms_implat False ethernet-main QoS Packet Scheduler ms_pacer True ethernet-main Internet Protocol Version 4 (TCP/IPv4) ms_tcpip True ethernet-main Client for Microsoft Networks ms_msclient True ethernet-main Intel(R) Advanced Network Services Protocol iANSProtocol False ethernet-main Microsoft LLDP Protocol Driver ms_lldp True ethernet-main Hyper-V Extensible Virtual Switch vms_pp False ethernet-main Link-Layer Topology Discovery Mapper I/O Driver ms_lltdio True ethernet-main File and Printer Sharing for Microsoft Networks ms_server True ethernet-main Internet Protocol Version 6 (TCP/IPv6) ms_tcpip6 True ethernet-main Win10Pcap Packet Capture Driver Win10Pcap True ethernet-main Link-Layer Topology Discovery Responder ms_rspndr True ethernet-main Npcap Packet Driver (NPCAP) INSECURE_NPCAP True ethernet-main Npcap Packet Driver (NPCAP) (Wi-Fi) INSECURE_NPCAP_WIFI True ethernet-main VirtualBox NDIS6 Bridged Networking Driver oracle_VBoxNetLwf True ethernet-main Bridge Driver ms_l2bridge True       PS C:\WINDOWS\system32>
Caguicla_Intel
Hello bilalu,
Please provide the System Support Utility log of your system. This will allow us to check your Adapter details and configuration. Kindly refer to the steps below.
a- https://downloadcenter.intel.com/product/91600/Intel-System-Support-Utility
b- Open SSU.exe
c- Mark the box "Everything" and then click "Scan".
d- When finished scanning, click "Next".
e- Click on "Save" and attach the file to a post.
We look forward to your reply.
Crisselle C
Intel Customer Support
A Contingent Worker at Intel
bilalu
Hi Chriselle,
Thanks for looking into our matter. I've attached the file to the associated support request (04310659).
bilalu
Caguicla_Intel
Hello Bilalu,
Thank you for providing the requested information.
While we are checking the logs, kindly share if you have tried performing clean installation of the network driver to check if it would be of help on fixing the issue?
Crisselle C
bilalu
Hi Chriselle,
I uninstalled the proset driver / software, restarted, installed it again, restarted again, and then ran some of the above commands before / after adding the VLANs. The result is identical.
Bilal
Caguicla_Intel
Hello Bilal,
We appreciate your response.
Please allow us to further check on this matter. Rest assured that we will give you an update after 1-3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello Bilal,
Thank you for the patience on this matter.
We would like to double check if you encountered the same issue reported on this thread?
https://forums.intel.com/s/question/0D50P000049QzW7/235-vlans-break-windows-powershell-getnetadapter?language=en_US
If yes, the fix for this issue will be incorporated in the next SW release. Please stay tune for the update.
We apologize for any inconvenience that this might have caused.
Crisselle C
bilalu
Hi Chriselle,
Precisely the same issue. Wow, it's been more than 8 months since it was reported. Any ETA when the next SW release is slated for release?
Is seems like 24.1 is the current / latest version as of 27th June 2019 (https://downloadcenter.intel.com/download/25016/Ethernet-Intel-Network-Adapter-Driver-for-Windows-10?wapkw=i210-t1).
The one before that was all the way back in Feb 2019, and yet the issue was confirmed by Intel in Dec 2018.
There's a workaround mentioned in the other ticket, but that just seems to be geared towards removing all VLANs, drivers, etc, and just installing it again, back to a zero state where no VLANs are defined, in which case, the commands work anyway.
I'll try the workaround anyway some time and report back...
Bilal
Caguicla_Intel
Hello Bilal,
We appreciate your prompt reply.
We will check with our engineers for the ETA of the next SW release where the fix will be incorporated.
We will be looking forward for your update once you've tried the workaround.
Have a lovely weekend!
Crisselle C
Caguicla_Intel
Hello Bilal,
Please accept our sincere apologies for any inconvenience that this might have caused. Unfortunately, there's no ETA on the SW release that will incorporate the fix. Please continue to monitor the  Intel Ethernet Forum for latest update.
Hoping for your patience and kind understanding on this matter.
Crisselle C
bilalu
Hi Chrisselle,
Thanks for your response.
Looks like Intel pulled the plug on the UI components a bit too early.
Bilal
bilalu
Hi Chriselle,
24.3 from the 4th of November 2019 is still broken!
Bilal
Caguicla_Intel
Hello Bilal,
How are today? I hope everything is great!
SW version 24.4 has just been released last December 16, 2019. With this, we would like to check if you have already test this version? If yes, kindly let us know if the latest version fixed the issue.
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapter-Complete-Driver-Pack
Crisselle C
bilalu
Hi Chriselle,
Great, thanks!
Ooh .. <hopes up>!
<hopes dashed> I'm having trouble with that driver pack. Something about the signing certificate being revoked.
Perhaps things will be right with 24.5?
Bilal
Caguicla_Intel
Hello Bilal,
Thank you for the prompt reply.
SW version 24.4 should include the fix for this issue.
Are there any changes on the device prior to update? Have you tried reinstalling the driver or performing clean driver installation?
Awaiting to hear from you.
Crisselle C
Caguicla_Intel
Hello Bilal,
Good day!
Please let us know if you were able to receive our previous post regarding this request.
Awaiting to your reply.
Crisselle C
bilalu
Hi Chriselle,
I was working with 24.4.
Here's the driver tab when 24.4 is installed, and it doesn't work due to the signing issue:
And here's the driver tab when I uninstall the Intel software package (and it works, but no iANS, etc):
2020-01-10 13_31_28-Control Panel_Network and Internet_Network Connections.png
Caguicla_Intel
Hello Bilal,
Thank you for the update.
Please allow us to further check on this. Rest assured that we will give you an update within 1-3 business days.
Crisselle C
Caguicla_Intel
Hello Bilal,
Good day!
While we are checking on the possible cause of the issue, we'd like to inform you that SW 24.5 was now released. Kindly try it out and feel free to update us anytime for the results.
Sharing the link for Intel® Ethernet Adapter Complete Driver Pack with you.
https://downloadcenter.intel.com/download/29320/Intel-Ethernet-Adapter-Complete-Driver-Pack
Hoping to hear form you soon.
Crisselle C
bilalu
Hi Chriselle,
Downloaded 24.5 and installed. Same issue. The underlying driver version is the same. "Windows cannot verify the digital signature for this file. The signing certificate for this file has been revoked.".
bilalu
Is there any other way to check why this is happening?
C:\>"C:\Program Files (x86)\Microsoft SDKs\ClickOnce\SignTool\signtool.exe" verify /v /pa c:\windows\system32\drivers\e1r68x64.sys   Verifying: c:\windows\system32\drivers\e1r68x64.sys Signature Index: 0 (Primary Signature) Hash of file (sha256): 352EB2CD9A9C2E73C92BF025EA0D2DA41E387F5B6ED4732B70E8E4A1AC33538F   Signing Certificate Chain: Issued to: COMODO RSA Certification Authority Issued by: COMODO RSA Certification Authority Expires: Tue Jan 19 10:59:59 2038 SHA1 hash: AFE5D244A8D1194230FF479FE2F897BBCD7A8CB4   Issued to: Intel External Issuing CA 7B Issued by: COMODO RSA Certification Authority Expires: Fri Jun 18 10:59:59 2021 SHA1 hash: A32F56A57D828436FAD2AD4EC1FADB66340C8D5A   Issued to: Intel(R) INTELND1820 Issued by: Intel External Issuing CA 7B Expires: Sun Aug 09 08:34:08 2020 SHA1 hash: CFED925A397EBE3072F8C907B246E841258FB16C   The signature is timestamped: Tue Nov 26 02:22:00 2019 Timestamp Verified by: Issued to: QuoVadis Root Certification Authority Issued by: QuoVadis Root Certification Authority Expires: Thu Mar 18 05:33:33 2021 SHA1 hash: DE3F40BD5093D39B6C60F6DABC076201008976C9   Issued to: QuoVadis Issuing CA G4 Issued by: QuoVadis Root Certification Authority Expires: Thu Mar 18 05:33:33 2021 SHA1 hash: D1B5123B31F19E1E00733F70DB93811547FAFFF7   Issued to: timestamp.intel.com Issued by: QuoVadis Issuing CA G4 Expires: Thu Mar 18 05:33:33 2021 SHA1 hash: 2B3A4E6B73785FDC9D736FB3CDD51A50919F37E2     Successfully verified: c:\windows\system32\drivers\e1r68x64.sys   Number of files successfully Verified: 1 Number of warnings: 0 Number of errors: 0   C:\>
