Ethernet Products
5741 Discussions
igb 0000:01:00.0: The NVM Checksum Is Not Valid
CondoMax20
Hello guys,
I have an issue with one of my device. My computer is a Ubuntu 14.04.5 LTS to which is connected a Intel I350 Gigabit Ethernet controller. When this device boots, i have an error with this NIC:
[ 4.669426] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.670124] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.691274] igb 0000:01:00.0: The NVM Checksum Is Not Valid
[ 4.870115] igb: probe of 0000:01:00.0 failed with error -5
[ 4.891251] igb 0000:01:00.1: The NVM Checksum Is Not Valid
[ 5.070115] igb: probe of 0000:01:00.1 failed with error -5
[ 5.100169] igb 0000:02:00.0: added PHC on eth1
[ 5.100811] igb 0000:02:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.101452] igb 0000:02:00.0: eth1: (PCIe:2.5Gb/s:Width x1) c4:00:ad:04:e8:3a
[ 5.102089] igb 0000:02:00.0: eth1: PBA No: FFFFFF-0FF
[ 5.102716] igb 0000:02:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[ 5.103367] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 5.104007] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 10.286287] igb 0000:02:00.0 p9p1: renamed from eth1
After some research, i've used the intel 's BOOTUTIL tool to try to reset the NIC but that didn't work.
Intel(R) Ethernet Flash Firmware Utility
BootUtil version 1.39.56.1
Copyright (C) 2003-2023 Intel Corporation
Type BootUtil -? for help
Port Network Address Location Series WOL Flash Firmware Version
1 C400AD04E839 0:31.6 Gigabit N/A FLASH Not Present
2 E8EA6A0C8468 1:00.0 Gigabit YES UEFI,PXE Enabled 1.5.61
3 E8EA6A0C8469 1:00.1 Gigabit YES UEFI,PXE Enabled 1.5.61
4 C400AD04E83A 2:00.0 Gigabit YES FLASH Not Present
Any Ideas on what i gotta do to fix this?
IntelSupport
Community Manager
Regarding your question booting error using Ubuntu 14.04.5 LTS that is connected to Intel I350 Gigabit Ethernet controller.
Please go through below link of Supported Operating Systems for Intel® Ethernet Controllers (LOM):
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
According to the link - the only supported OS version for Ubuntu are Ubuntu*22.04 LTS and Ubuntu*20.04 LTS.
I would suggest that you update the OS to the version that is compatible as well as update the driver to the latest version.
Below link is the latest driver version for
https://www.intel.com/content/www/us/en/download/14098/intel-network-adapter-driver-for-82575-6-82580-i350-and-i210-211-based-gigabit-network-connections-for-linux.html
Kindly update on more details of Intel I350 Gigabit Ethernet controller specification that you are using.
Please let us know the outcome after you have checked it and will be happy to assist if any other troubleshooting required for this issue.
Hayat
CondoMax20
I understand that this Linux version isn't compatible with this NIC according to your table, but i have 4 other computer with exactly the same configuration and hardware and they are working just fine like this which is why i don't think there is a driver or compatibility issue
IntelSupport
Community Manager
Hello CondoMax20,
Thank you for your response.
In order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Hayat
CondoMax20
It's a Linux OS, not windows. Do you have the linux equivalent?
CondoMax20
After several research, i managed to get my NIC working using Bootutil -all -fe to enable flash. But i still only see 2 interfaces for my  I350 NIC instead of 4
IntelSupport
Community Manager
Hello CondoMax20,
Thank you for your reply. I am glad the NIC started working for you. We will investigate further once we receive the SSU logs.
Use below link to provide the SSU for Linux:
https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html?wapkw=ssu
Hayat
IntelSupport
Community Manager
Hello CondoMax20,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Else if none, we will proceed to close the case.
Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
IntelSupport
Community Manager
Hello CondoMax20,
This message is to inform you about the thread closure.
Once the thread is closed, it will no longer be monitored by Intel.
Kindly submit a new thread should you need further assistance. We will be more than glad to continue assisting you.
Hayat
