Ethernet Products
5716 Discussions
intel ethernet connection i219-v code 10 Error all the time
JWilk6
First i am from germany so sry for my english at some points.
I build a new pc installed all drivers. All are working fine but the driver for the Ethernet adapter is just not working. I installed the Driver cd from the mainboard did not work, I installed the intel Driver did not work and i installed driver from the mainboard website did not work also....
What can i do i installed windows again it did not help.
Did a Cmos reset did not help.
Checket the bios settings did not help.
I Need help....
Thanks for reading
Taktlos.
Hi Taktlos,
Thank you for the post. Error code 10 is an indication of the device not started or driver issue, you may refer to this website (note this is 3rd party website for reference, Intel has no control over the content) https://support.microsoft.com/en-ph/help/943104/-this-device-cannot-start-code-10-error-in-device-manager-in-windows
As this is an onboard NIC, you can check with the board vendor for latest BIOS. Can you also tell me what is the brand and model of the board?
wb
Hi Taktlos,
Please feel free to update me if you have contacted the board vendor, any further inquiries?
Rgds,
wb
