Ethernet Products
5821 Discussions
SNMP for Intel ET Gigabit Dual Port server addapter issue with ANS
RRina
Hello.
I started a new thread, because the old thread ( ) don't have any answer from Intel's team since 2013 year.
I have installed the last version of PROWinx32.exe (21.1) with activation of the SNMP option on Windows 7 (32-bit).
I have configured an AFT teaming from two network interfaces. By using PROSetCL.exe, I have checked that this teaming works correctly.
My problem is when I make a SNMP dump of the intel-Ian-adapters MIB, I have the following results:
  • baseDriverLoadedAnsNotLoaded(1) for the status when I am expecting baseDriverLoadedAnsLoaded(3)
  • standAlone(0) for the type of the adapters involved in the teaming when I am expecting teamMember(1)
  • no data under ansAttrTables MIB subtree.
Previously, we used data from ansAttrTable MIB subtree on Windows XP with PROWin32.exe (v16.3) without any problems.
Under Windows 7 with the same (v16.3) driver and latest (v21.1) driver no data under ansAttrTable MIB subtree.
Is there something specific to do to have ANS loaded at SNMP level ?
Hi RinatGadelshin,
Thank you for the post. I will need to investigate on this.
rgds,
wb
RRina
Hello =)
I use the following tools:
- Windows 7 professional SP1 (32-bit)
- Driver PROWinx32.exe ( version 21.1 ).
- iReasoning MIB Browser, for checking snmp data.
Component SNMP Service is turned on.
Read-only community for SNMP Service is "public"
SNMP Service listen any host.
Is more information needed?
Hi RinatGadelshin,
Thank you for the information. Further checking, currently you have a case open for investigation in 02191704. The case is being handled accordingly, you may continue your inquiry from the existing case there.
wb
RRina
Hello!
Please, tell me, where I can see "a case open for investigation in 02191704" for "continue my inquiry"?
Rinat
Hi Rinat,
There was an email you sent to our support in Russia dated Dec 15 and currently the case is being handled.
wb
RRina
Hello!
I have been received mail from Russian support today.
Do you need any more info about this issue?
Rinat
Hi Rinat,
Thank you for the update. You can continue to contact our Russian support for them to assist you. No information needed here.
wb
RRina
Russian support told me this network card and Windows 7 is no longer supported.
Translation from russian:
"Intel® 82576EB Gigabit Ethernet Controller and Intel® Advanced Network Services in stage SM2 "End Of Life",
Windows 7 - in stage SM1 "End Of Life".
SM1 means that we will correct serious bugs only,
SM2 means that the support is practically finished."
Oops!
OK.
Next question: has Intel any dual port gigabit ethernet controller with teaming and snmp support for Windows 7 (or Windows 10)?
Rinat
Hi Rinat,
Thank you for the update. You can refer to below URL for a list of Intel server adapters or ethernet controllers for reference:
1) https://ark.intel.com/products/family/46829/Intel-Gigabit-Server-Adapters
2) https://ark.intel.com/products/family/2469/Intel-Gigabit-Ethernet-Network-Connection
e.g. I350-T2V2 is a standalone dual port server adapter which can support Windows 7 and teaming.
https://ark.intel.com/products/84804/Intel-Ethernet-Server-Adapter-I350-T2V2
https://downloadcenter.intel.com/product/84804/Intel-Ethernet-Server-Adapter-I350-T2V2
I350-AM2 for ethernet controller
https://ark.intel.com/products/52968/Intel-Ethernet-Controller-I350-AM2
Please refer to the data sheet for more information to see if the ethernet controller or adapter meets your requirement.
wb
