- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hello.
I started a new thread, because the old thread ( ) don't have any answer from Intel's team since 2013 year.
I have installed the last version of PROWinx32.exe (21.1) with activation of the SNMP option on Windows 7 (32-bit).
I have configured an AFT teaming from two network interfaces. By using PROSetCL.exe, I have checked that this teaming works correctly.
My problem is when I make a SNMP dump of the intel-Ian-adapters MIB, I have the following results:
- baseDriverLoadedAnsNotLoaded(1) for the status when I am expecting baseDriverLoadedAnsLoaded(3)
- standAlone(0) for the type of the adapters involved in the teaming when I am expecting teamMember(1)
- no data under ansAttrTables MIB subtree.
Previously, we used data from ansAttrTable MIB subtree on Windows XP with PROWin32.exe (v16.3) without any problems.
Under Windows 7 with the same (v16.3) driver and latest (v21.1) driver no data under ansAttrTable MIB subtree.
Is there something specific to do to have ANS loaded at SNMP level ?
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi RinatGadelshin,
Thank you for the post. I will need to investigate on this.
rgds,
wb
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello =)
I use the following tools:
- Windows 7 professional SP1 (32-bit)
- Driver PROWinx32.exe ( version 21.1 ).
- iReasoning MIB Browser, for checking snmp data.
Component SNMP Service is turned on.
Read-only community for SNMP Service is "public"
SNMP Service listen any host.
Is more information needed?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi RinatGadelshin,
Thank you for the information. Further checking, currently you have a case open for investigation in 02191704. The case is being handled accordingly, you may continue your inquiry from the existing case there.
wb
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello!
Please, tell me, where I can see "a case open for investigation in 02191704" for "continue my inquiry"?
Rinat
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Rinat,
There was an email you sent to our support in Russia dated Dec 15 and currently the case is being handled.
wb
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello!
I have been received mail from Russian support today.
Do you need any more info about this issue?
Rinat
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Rinat,
Thank you for the update. You can continue to contact our Russian support for them to assist you. No information needed here.
wb
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Russian support told me this network card and Windows 7 is no longer supported.
Translation from russian:
"Intel® 82576EB Gigabit Ethernet Controller and Intel® Advanced Network Services in stage SM2 "End Of Life",
Windows 7 - in stage SM1 "End Of Life".
SM1 means that we will correct serious bugs only,
SM2 means that the support is practically finished."
Oops!
OK.
Next question: has Intel any dual port gigabit ethernet controller with teaming and snmp support for Windows 7 (or Windows 10)?
Rinat
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Rinat,
Thank you for the update. You can refer to below URL for a list of Intel server adapters or ethernet controllers for reference:
1) https://ark.intel.com/products/family/46829/Intel-Gigabit-Server-Adapters
2) https://ark.intel.com/products/family/2469/Intel-Gigabit-Ethernet-Network-Connection
e.g. I350-T2V2 is a standalone dual port server adapter which can support Windows 7 and teaming.
https://ark.intel.com/products/84804/Intel-Ethernet-Server-Adapter-I350-T2V2
https://downloadcenter.intel.com/product/84804/Intel-Ethernet-Server-Adapter-I350-T2V2
I350-AM2 for ethernet controller
https://ark.intel.com/products/52968/Intel-Ethernet-Controller-I350-AM2
Please refer to the data sheet for more information to see if the ethernet controller or adapter meets your requirement.
wb
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
