Ethernet Products
5868 Discussions
intel i210-t1 NIC adapter settings
owie
Quick question: Does DMA coalescing work together when low latency interrupt is enabled? according to intel Disabling Interrupt Moderation will also disable DMA Coalescing. Also does interrupt moderation work as well when low latency interrupt is enabled? Thank you
Sazirah
 Hi owie,
Regarding your enquiry, please give me some time to check from my end and I will get back to you from time to time.
Sazzy_Intel
Sazirah
Hi owie,
Please find some information regarding DMA Coalescing in link below (this is applicable for your product Intel I210-T1):
https://www.intel.com/content/dam/support/us/en/documents/network/adapter/pro100/sb/466827_intel_r__dma_coalescing_white_paper_v003.pdf
Let us know if you have further questions on this.
Sazzy
Sazirah
Hi owie,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Sazirah
Hi owie,
Good day
This is regarding your enquiries above. Since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
