Ethernet Products
5759 Discussions
ipv6 Multicast I219 during sleep
HIT-S
I have a Problem with the I219-LM and I219-V network interfaces, when the Machines going to sleep. They massivly flood the Network with ipv6-Multicast. I tried the latest Driver, but nothing changed. I have ~450 clients in the Network and just some of them have this Problem.
Mike_Intel
Hello HIT-S,
For me to further understand the issue, please provide the following details:
  1. What is your OS?
  2. What is the driver version used?
  3. Is it working fine before?
  4. Can you provide any data of the ipv6-Multicast flood?
  5. Are you using on-board NIC's?
  6. What is the model of your board or system?
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
HIT-S
Hello Mike,
we use Lenovo M900t, M910t, M920t, L470, L480, L490, T480 and T490 Models with onboard-NICs. The Problem Is only with Windows 10 (1709 - 1903). With Linux (Ubuntu / Debian) there is no Problem. The first models came with the 22.3 driver. Lenovo it self delivers the Computers today with a Version from 04.10.2018 (12.18.8.4) We tried all drivers from 22.10 to 24.2 (16.08.2019).
an example for a WireShark sniff:
each of this packages contains:
Frame 15: 86 bytes on wire (688 bits), 86 bytes captured (688 bits) on interface 0 Interface id: 0 (\Device\NPF_{D9E96F4D-2921-4979-A834-75634655CC5E}) Encapsulation type: Ethernet (1) Arrival Time: Aug 17, 2019 21:33:49.949927000 Mitteleuropäische Sommerzeit [Time shift for this packet: 0.000000000 seconds] Epoch Time: 1566070429.949927000 seconds [Time delta from previous captured frame: 0.000001000 seconds] [Time delta from previous displayed frame: 0.000001000 seconds] [Time since reference or first frame: 0.002978000 seconds] Frame Number: 15 Frame Length: 86 bytes (688 bits) Capture Length: 86 bytes (688 bits) [Frame is marked: False] [Frame is ignored: False] [Protocols in frame: eth:ethertype:ipv6:ipv6.hopopts:icmpv6] [Coloring Rule Name: ICMP] [Coloring Rule String: icmp || icmpv6] Ethernet II, Src: Micro-St_f7:db:5c (30:9c:23:f7:db:5c), Dst: IPv6mcast_01 (33:33:00:00:00:01) Destination: IPv6mcast_01 (33:33:00:00:00:01) Source: Micro-St_f7:db:5c (30:9c:23:f7:db:5c) Type: IPv6 (0x86dd) Internet Protocol Version 6, Src: fe80::329c:23ff:fef7:db5c, Dst: ff02::1:ff23:f7db 0110 .... = Version: 6 .... 0000 0000 .... .... .... .... .... = Traffic Class: 0x00 (DSCP: CS0, ECN: Not-ECT) .... .... .... 0000 0000 0000 0000 0000 = Flow Label: 0x00000 Payload Length: 32 Next Header: IPv6 Hop-by-Hop Option (0) Hop Limit: 1 Source: fe80::329c:23ff:fef7:db5c Destination: ff02::1:ff23:f7db [Source SA MAC: Micro-St_f7:db:5c (30:9c:23:f7:db:5c)] IPv6 Hop-by-Hop Option Internet Control Message Protocol v6 Type: Multicast Listener Report (131) Code: 0 Checksum: 0x6134 [correct] [Checksum Status: Good] Maximum Response Delay [ms]: 0 Reserved: 0000 Multicast Address: ff02::1:ff23:f7db
There was no before. It was just sometimes, that a switch-port was shut down, but in the last couple of month, the amount of Multicast-Storms is rising.
In 2013/14 there was a similar Problem with the I217 Chips. By then we just putted other NICs in the PCs. At this time we had about 150 PCs and like 50 where affected.
After a year or so, Intel delivered a new Driver and the Problem was gone.
At this Time many People complaint about the issue.
Today I feel like I'm the first.
Thank you very much for your quick response.
Philipp L.
Mike_Intel
Hello HIT-S,
Thank you for the quick response. Since you tried the latest drivers from us which is only generic drivers that we can recommend. At this point, have you tried contacting Lenovo for further support since the NIC's are all on-board?
Michael L.
Mike_Intel
Hello HIT-S,
I just want to check if you already tried contacting Lenovo regarding this issue?
Michael L.
HIT-S
Hello Mike,
we have opened a case with Lenovo but till now have had no response. We are still having severe network floods (Mutlicast Listener Report). They come everyday. It is hard to believe that we are the only ones with this problem.
Kind regards
Luca G.
Mike_Intel
Hello HIT-S,
I understand. However, OEM and on-board NIC's may have altered specifications and features and the manufacturer should provide the appropriate driver since they made some changes. Since just like what you said, you are having this issue, it is best to communicate the issue with Lenovo.
Michael L.
Mike_Intel
Hello HIT-S,
I just want to check if you already contacted Lenovo regarding this issue and I hope that they are already looking into this issue.
Michael L.
Mike_Intel
Hello HIT-S,
I have not heard back from you so I will close this inquiry now.
If you need further assistance, please post a new question.
Michael L.
