Ethernet Products
5686 Discussions
ixgbe: reply to IXGBE_VF_RESET is lost, because of ixgbe_ping_all_vfs()
ALyak
Greeting all,
we are seeing the following issue:
A VF sends IXGBE_VF_RESET to its PF. This message is successfully accepted by the PF and handled in ixgbe_vf_reset_msg():
e_info(probe, "VF Reset msg received from vf %d\n", vf);
/* reply to reset with ack and vf mac address */
msgbuf[0] = IXGBE_VF_RESET | IXGBE_VT_MSGTYPE_ACK;
ixgbe_write_mbx(hw, msgbuf, IXGBE_VF_PERMADDR_MSG_LEN, vf);
return 0;
However, immediately after that, the PF "feels" that its link is up, and ixgbe_watchdog_link_is_up() does:
e_info(drv, "NIC Link is Up %s, Flow Control: %s\n",
(link_speed == IXGBE_LINK_SPEED_10GB_FULL ?
"10 Gbps" :
(link_speed == IXGBE_LINK_SPEED_1GB_FULL ?
"1 Gbps" :
(link_speed == IXGBE_LINK_SPEED_100_FULL ?
"100 Mbps" :
"unknown speed"))),
((flow_rx && flow_tx) ? "RX/TX" :
(flow_rx ? "RX" :
(flow_tx ? "TX" : "None"))));
/* ping all the active vfs to let them know link has changed */
ixgbe_ping_all_vfs(adapter);
and ixgbe_ping_all_vfs() does for each VF:
ping = IXGBE_PF_CONTROL_MSG;
if (adapter->vfinfo[i].clear_to_send)
ping |= IXGBE_VT_MSGTYPE_CTS;
ixgbe_write_mbx(hw, &ping, 1, i);
So the VF receives a reply, which is:
IXGBE_PF_CONTROL_MSG|IXGBE_VT_MSGTYPE_CTS = 0x20000100
and not the expected
IXGBE_VF_RESET|IXGBE_VT_MSGTYPE_ACK = 0x80000001
So the VF thinks that the PF is "still resetting".
In this particular case, we were trying to add the VF to the bond, and this operation failed due to the above problem.
How this issue can be addressed?
Driver versions:
ixgbe: 3.11.33
ixgbevf: version that comes with Ubuntu Precise 3.2.0-29.46 plus the patch "[net] ixgbevf: fix VF untagging when 802.1 prio is set"
from here:
http://permalink.gmane.org/gmane.linux.network/237391 http://permalink.gmane.org/gmane.linux.network/237391
Thanks!
Alex.
Below is the relevant part of the kernel log from ixgbe and ixgbevf (with added debug prints):
Jan 26 10:38:09 01-04 kernel: [ 11.541962] bonding: febond: Adding slave fe10G2.
Jan 26 10:38:09 01-04 kernel: [ 11.542058] ixgbevf_open: === hw->adapter_stopped
Jan 26 10:38:09 01-04 kernel: [ 11.542059] ixgbevf_reset: === ENTER
Jan 26 10:38:09 01-04 kernel: [ 11.542060] ixgbevf_reset_hw_vf: === ENTER
Jan 26 10:38:09 01-04 kernel: [ 11.542130] ixgbe 0000:03:00.1: eth10G2: VF Reset msg received from vf 0
Jan 26 10:38:09 01-04 kernel: [ 11.542374] Send VF Reset msg REPLY to vf 0
Jan 26 10:38:09 01-04 kernel: [ 11.542428] ixgbe 0000:03:00.1: eth10G2: NIC Link is Up 10 Gbps, Flow Control: RX/TX
Jan 26 10:38:09 01-04 kernel: [ 11.542433] ixgbe_ping_all_vfs: ping VF 0
Jan 26 10:38:09 01-04 kernel: [ 11.542435] ixgbe_ping_all_vfs: ping VF 1
Jan 26 10:38:09 01-04 kernel: [ 11.542437] ixgbe_ping_all_vfs: ping VF 2
Jan 26 10:38:09 01-04 kernel: [ 11.542443] ixgbe_ping_all_vfs: ping VF 3
Jan 26 10:38:09 01-04 kernel: [ 11.542445] ixgbe_ping_all_vfs: ping VF 4
Jan 26 10:38:09 01-04 kernel: [ 11.542447] ixgbe_ping_all_vfs: ping VF 5
Jan 26 10:38:09 01-04 kernel: [ 11.542449] ixgbe_ping_all_vfs: ping VF 6
Jan 26 10:38:09 01-04 kernel: [ 11.542452] ixgbe_ping_all_vfs: ping VF 7
Jan 26 10:38:09 01-04 kernel: [ 11.542454] ixgbe_ping_all_vfs: ping VF 8
Jan 26 10:38:09 01-04 kernel: [ 11.542456] ixgbe_ping_all_vfs: ping VF 9
Jan 26 10:38:09 01-04 kernel: [ 11.542459] ixgbe_ping_all_vfs: ping VF 10
Jan 26 10:38:09 01-04 kernel: [ 11.542461] ixgbe_ping_all_vfs: ping VF 11
Jan 26 10:38:09 01-04 kernel: [ 11.542463] ixgbe_ping_all_vfs: ping VF 12
Jan 26 10:38:09 01-04 kernel: [ 11.542465] ixgbe_ping_all_vfs: ping VF 13
Jan 26 10:38:09 01-04 kernel: [ 11.542468] ixgbe_ping_all_vfs: ping VF 14
Jan 26 10:38:09 01-04 kernel: [ 11.542470] ixgbe_ping_all_vfs: ping VF 15
Jan 26 10:38:09 01-04 kernel: [ 11.542472] ixgbe_ping_all_vfs: ping VF 16
Jan 26 10:38:09 01-04 kernel: [ 11.542474] ixgbe_ping_all_vfs: ping VF 17
Jan 26 10:38:09 01-04 kernel: [ 11.542477] ixgbe_ping_all_vfs: ping VF 18
Jan 26 10:38:09 01-04 kernel: [ 11.542479] ixgbe_ping_all_vfs: ping VF 19
Jan 26 10:38:09 01-04 kernel: [ 11.542481] ixgbe_ping_all_vfs: ping VF 20
Jan 26 10:38:09 01-04 kernel: [ 11.542483] ixgbe_ping_all_vfs: ping VF 21
Jan 26 10:38:09 01-04 kernel: [ 11.542486] ixgbe_ping_all_vfs: ping VF 22
Jan 26 10:38:09 01-04 kernel: [ 11.542488] ixgbe_ping_all_vfs: ping VF 23
Jan 26 10:38:09 01-04 kernel: [ 11.542490] ixgbe_ping_all_vfs: ping VF 24
Jan 26 10:38:09 01-04 kernel: [ 11.542493] ixgbe_ping_all_vfs: ping VF 25
Jan 26 10:38:09 01-04 kernel: [ 11.542495] ixgbe_ping_all_vfs: ping VF 26
Jan 26 10:38:09 01-04 kernel: [ 11.542497] ixgbe_ping_all_vfs: ping VF 27
Jan 26 10:38:09 01-04 kernel: [ 11.542499] ixgbe_ping_all_vfs: ping VF 28
Jan 26 10:38:09 01-04 kernel: [ 11.542502] ixgbe_ping_all_vfs: ping VF 29
Jan 26 10:38:09 01-04 kernel: [ 11.542504]...
Patrick_K_Intel1
Have you tried this with the latest drivers? It appears your PF is a bit old. Latest PF is 3.19.1 and VF is 2.12.1.
- Patrick
