Ethernet Products
5537 Discussions
killer ethernet 2500 version 2 slow upload speeds
TDHC13
I have an ethernet problem - high download speeds and very low upload speeds. Tried changing the cable, and uninstalling, and installing the killer ethernet driver and software multiple times, which initially provided only a temporary fix.  Now I get the same low upload speed results even after completing the fresh installation of the new driver.  Please help.
TDHC13
Hello Everyone: I discovered that my adapter settings, particularly my off load settings, were causing my slow upload speeds. Disabled, and I am now getting 500/500 Mbps, which is what I am contracted to receive from my fiber optic ISP.  Also confirmed the settings recommended by Shaq. Problem resolved.
Thank you.
Tim
TDHC13
I'm using MSI GE75 Raider 9SF
Device name Timslaptop
Processor Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.59 GHz
Installed RAM 16.0 GB (15.8 GB usable)
Device ID 57044B56-95F3-4EA4-9761-4BF79DF630A2
Product ID 00325-81502-66462-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Shaq_Intel
Hi TDHC13,
As for your issue, you can check the below article to set your upload speed and download speed. You can go to the same section and adjust the transmit and received buffer to 1024. Make sure to check if the speed and duplex is set to auto negotiation if available.
https://www.intel.com/content/www/us/en/support/articles/000058908/ethernet-products/intel-killer-ethernet-products.html
Shaq_Intel
TDHC13
Thank you.
Tim
jamal976
HI
Hello . I can confirm it . I had the issue for than one year ..By doing this, it fixed my issue
TDHC13
Thank you.
Tim
Shaq_Intel
Hi THDC13,
I am glad that your issue is already solved. If there is no other issue regarding this matter, I will be closing this issue/thread.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Have a good day and Thank you for reaching out to Intel Community Support.
Shaq_Intel
