Ethernet Products
5782 Discussions
recommending a config for a 2 node S2D cluster (W2019). Direct connect of NIC is supported by MS. Questions: 1. Can I direct connect two X722DA4FH cards with a copper DAC cable? 2. Can I connect more than one port/NIC to give 20, 30, or 40GB connection?
GRobe
Caguicla_Intel
Hello GRobe,
Please allow us to check on your request. We will get back to you to give an update within 1-3 business days.
Hoping for your patience.
Crisselle C
Intel® Customer Support
A Contingent Worker at Intel
Caguicla_Intel
Hello GRobe,
Thank you for the patience on this matter.
1.) We've tried to use DAC cable in the lab for 10Gb back-to-back connection. Please be informed that Intel® Ethernet Network Adapter X722 only supports 10GbE connectivity.
Please visit the link below and scroll down to Features>SFP+ Connectitivity for more details.
https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-network-adapter-x722-product-brief.pdf
2.) Regarding your question number 2, we'd like to verify if you are referring to Teaming configuration.
Crisselle C
GRobe
GRobe
so it worked? you connected two X722 together at 10GB with a DAC?
Caguicla_Intel
Hello GRobe,
Thank you for the prompt reply.
Yes it is working. However, can you share the intended configuration so we can further investigate on this?
For teaming, please provide the exact model of the intended adapters to be used.
We look forward to your reply.
Should there be no response from you, we'll reach out after 3 business days.
Crisselle C
GRobe
want to use two R1208WFTYS with config: Dual Xeon Silver 4208, 192GB RAM, Single 480GB M.2 Boot, 4 x 4TB P4510 NVMe SSD, VROC, RPS, 2 x 10GbE Base-T, 4 x 10GbE SFP+ (RDMA), Remote Management, Rail Kit running Windows 2019 DC Software Spaces Direct. Plan is to direct connect the two nodes using a DAC between them connecting two X722-DA4 ports.
Also if a customer wants 20GB, 30GB or 40GB between nodes in the future can he connect the ports together and "bond" the connections - sorry am in Sales - is that what you call "teaming"?
Caguicla_Intel
Hello GRobe,
No problem at all. We totally understand that you are in sales so we will do our best to explain our answer in a simple way.
Please share what is the intended use of the server? Regarding your question if you would connect more than one port/NIC to give 20, 30, or 40GB connection. Unfortunately, the X722-DA4 is only capable of 10GbE connection. You may refer to the link below for more information regarding teaming.
https://www.intel.sg/content/www/xa/en/support/articles/000005667/network-and-i-o/ethernet-products.html
Let us know if you have additional questions and clarifications.
In case we don't receive a reply, we'll follow up after 3 business days.
Crisselle C
Caguicla_Intel
Hello GRobe,
Good day!
We'd like to check if you have additional questions and clarifications on this matter. In case you do, please do not hesitate to let us know.
Awaiting to your response.
Should there be no response from you, we'll follow up after 3 business days.
Crisselle C
Caguicla_Intel
Hello GRobe,
Good day!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future.
Crisselle C
