Dears, I use sr-iov vf for docker network device by kubernetes, but there has a bigger probability of system reboot
syslogs record nothing, and only happened when there are release & allocate VF
what should I do for solve this problem?
My environment:
BIOS already enabled VT-d and SR-IOV global enable
os is ubuntu 16.04, kernel version 4.10, options is
BOOT_IMAGE=/vmlinuz-4.10.0-35-lowlatency root=UUID=xxxx ro cgroup_enable=memory swapaccount=1 intel_iommu=on iommu=pt
set max_vfs to 63
echo 63 >/sys/class/net/enp4s0f1/device/sriov_numvfs
PCI device info
04:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
04:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
04:10.1 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
04:10.3 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
$ ethtool -i enp4s0f1
driver: ixgbe
version: 4.4.0-k
firmware-version: 0x800007f5
expansion-rom-version:
bus-info: 0000:04:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
Hello SchoIsles,
In order to get you a more accurate response we're moving your thread over to our /community/tech/wired Wired Ethernet Support Community.
Carlos A.
Hi Scholsles,
Thank you for writing to Wired Communities. What is the exact X520 network adapter you have?
Can you type lspci -nn | grep -i 'Ethernet Controller command to share the device and vendor ID output?
Please elaborate more about the release and allocate of VF(virtual function)
Where did you download the driver?
Please feel free to update me.
Sharon
Hi Scholsles,
Please feel free to provide the information so that I can better check for you.
Sharon T
