Hi Intel support:
When I try to install DPDK and run testpmd,No probed ethernet devices always returned and can not forwad any packet .Test NIC is Intel E810XXVDA2G1P5.
Attached all test logs for details.
Pls check to check what may cuase the issue and what method I can try to solve the issue?
Thanks a lot.
BR,
wangjing
Hi 蓝月飞雪,
For Support with DPDK we recommend refer to DPDK.org site or open an IPS case at IPS Support site (it will require for Sign in or Sign up) as per link below:
DPDK.org
Intel® Premier Support Access (Kindly refer instruction on the webpage for login step)
https://www.intel.com/content/www/us/en/design/support/ips/training/access-and-login.html
In case you still have inquiry within inside Intel Communities you may post it to a forum as per link below
Embedded Connectivity Forum:
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Fariz_Intel
Hi ,
Thanks for reply.I had submit a ticket to DPDK.org for support.We can close this topic here.
BR,
wangjing
Hi wangjing,
Noted, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Fariz_Intel
