Ethernet Products
5692 Discussions
v24.5 Drivers for Intel I211 on Windows 10 64-bit not working
BGhos2
I get this error after updating the drivers:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Windows cannot verify the digital signature for this file. The signing certificate for this file has been revoked."
The interface disappears from available adapters and I lose connectivity, rolling back to v24.3 works, please help. thank you.
BGhos2
CUllr
Looks good. Even better, it also does not break WMI anymore.
Wagnerfc
Hello can u help me when i connect the ONU in router wan port the the lan (gigabit) port stops working and give error 27 e1express the ligth of LAN turn off and the ligths of ethernet in the motherboard turn off too. When i reset the router the conection back, but if i plug the ONU in WAN port this error happen.
Jfoster84
I downloaded the update along with proset just to find out I am still having this same issue and getting  ¨Miniport Intel(R) I211 Gigabit Network Connection, {d836382b-66c2-494d-9f4e-1bb3460103f9}, had event Fatal error: The miniport has detected an internal error¨.
I have done everything that has been suggested. I am unsure what else to do.
Caguicla_Intel
Hello BGhos2 & CUllr,
Thank you for the update.
We are glad to hear that the latest version is working as expected and fixed the issue. With this, please be informed that we will now proceed in closing this request. If you may have any other inquiry in the future, please feel free to post a new question.
May you have a lovely day!
Crisselle C
Intel® Customer Support
wbedard
+1. Also seeing this issue on Win10 x64 1909 using v25.0 Ethernet drivers.
Caguicla_Intel
Hello wbedard,
Thank you for raising this concern.
Are you using a fresh install Operating system? Have you tried to reinstall the driver of perform clean driver installation? Please share the exact model of the Ethernet Adapter used.
Should there be no response from you, we'll follow up after 3 business days.
Crisselle C
wbedard
Although it is not a "new install" for the OS, it's a relatively new device ( Intel NUC8i7HVK ) having been purchased/setup in the past 6 months. Like others in this thread, I just uninstalled the existing version of the Intel driver package and re-installed v24.3, which resolved the issue for me.
R/
wbedard
Caguicla_Intel
Hello wbedard,
The issue with the certificate for the E1R driver is fixed in SW 25.0 release. Can you share the exact error message you got when updating the driver to latest version?
Looking forward to hear from you.
Should there be no response form you, we'll follow up after 3 business days.
Crisselle C
BGhos2
Caguicla_Intel
Hello wbedard,
Good day!
We'd like to check if you have received our message few days ago. In case you have additional questions, please let us know.
Awaiting to your reply.
Crisselle C
Caguicla_Intel
Hello wbedard,
Good day!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future.
Crisselle C
