Ethernet Products
5115 Discussions
vxlan: non-ECT with TOS=0x02 logs were generated
Hi
I use intel 1G and 10G ethernet card with openvswitch under vxlan overlay network.
Some VM started to use ECN and I found weird logs were generated about non-ECT.
I checked vxlan packets, but all packets had no errors. Also, vxlan outer header's ECN was normal acording to RFC6040.
I changed ethernet card to Broadcom, and I found there was no non-ECT log.
I need to stop wrong non-ECT logs. How should I do?
Please see below informations:
[root@compute01 ~]# grep vxlan /var/log/messages | tail
Dec 13 10:32:57 compute01 kernel: vxlan: non-ECT from 192.168.40.55 with TOS=0x2
Dec 13 10:33:32 compute01 kernel: vxlan: non-ECT from 192.168.40.55 with TOS=0x2
Dec 13 10:33:34 compute01 kernel: vxlan: non-ECT from 192.168.40.55 with TOS=0x2
[root@compute01 ~]# uname -a
Linux compute01 3.10.0-693.5.2.el7.x86_64 # 1 SMP Fri Oct 20 20:32:50 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
[root@compute01 ~]# ethtool -i eth4
driver: ixgbe
version: 4.4.0-k-rh7.4
firmware-version: 0x80000609
expansion-rom-version:
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
[root@compute01 ~]# ethtool -k eth4
Features for eth4:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: on [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
tx-tcp-mangleid-segmentation: off
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: on [fixed]
tx-gre-segmentation: on
tx-ipip-segmentation: on
tx-sit-segmentation: on
tx-udp_tnl-segmentation: on
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
busy-poll: on [fixed]
tx-gre-csum-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
l2-fwd-offload: off
hw-tc-offload: off [fixed]
root@oscompute01:~# grep vxlan /var/log/syslog | tail
Dec 13 18:53:50 oscompute01 kernel: [188924.432135] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:51 oscompute01 kernel: [188925.431957] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:51 oscompute01 kernel: [188925.432004] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:51 oscompute01 kernel: [188925.447808] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:52 oscompute01 kernel: [188926.447743] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:52 oscompute01 kernel: [188926.463339] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:54 oscompute01 kernel: [188928.463280] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:54 oscompute01 kernel: [188928.478883] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:55 oscompute01 kernel: [188929.463051] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
Dec 13 18:53:55 oscompute01 kernel: [188929.478835] vxlan: non-ECT from 192.168.2.32 with TOS=0x2
root@oscompute01:~# uname -a
Linux oscompute01 4.4.0-103-generic # 126-Ubuntu SMP Mon Dec 4 16:23:28 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
root@oscompute01:~# ethtool -i eth1
driver: igb
version: 5.3.5.12
firmware-version: 1.70, 0x80000f44, 1.1752.0
bus-info: 0000:04:00.1
supports-test: yes
root@oscompute01:~# ethtool -k eth1
Features for eth1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: ontx-checksum-ip-generic: off [fixed]tx-checksum-ipv6: ontx-checksum-fcoe-crc: off [fixed]tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: ontx-scatter-gather-fraglist: off [fixed]
tx-tcp-segmentation: ontx-tcp-ecn-segmentation: off [fixed]tx-tcp6-segmentation: on
large-receive-offload: off [requested on]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off [fixed]
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
<p...
Hi Woobee,
Thank you for posting in Wired Communities. Can you share what is the model of the Intel NIC you used? Are they onboard NIC or standalone NIC?
Sharon
Hi Sharon,
I used I350 as a standalone NIC, and X540 as a onboard(LOM) NIC.
- HP 669280-001 Ethernet 1Gb 4-Port 366FLR Adapter
- HP 701525-001 ETHERNET 10GB 2-PORT 561FLR-T ADAPTER
If you want to reproduce ECN easily in lab, please refer below url:
https://gist.github.com/bauer1j/1320355/ef7a8aad7373858cc6230f05f2d9c0f02aee5348 https://gist.github.com/bauer1j/1320355/ef7a8aad7373858cc6230f05f2d9c0f02aee5348
Woobee
Hi Woobee,
Thank you for the information. I will further investigate and update you if there is any finding.
Sharon
Hi Woobee,
Please try using the driver below for the Intel NICs. Do let me know the result.
https://sourceforge.net/projects/e1000/files/?source=navbar
Sharon
Hi Sharon,
I've already used recent drivers, but result were same as before.
- igb stable 5.3.5.12 (lastest driver is 5.3.5.12)
- ixgbe stable 5.3.3 (lastest driver is 5.3.4)
Woobee
Hi Woobee,
Thank you for the update. I will further check on this.
Sharon
Hi Woobee,
Just to double check I found that you are using HP* network adapter as you mentioned you are using I350 and X540 with below part number
These are HP* network adapters, have you contacted HP* for the support?
Sharon
Hi Sharon,
I requested support to HP, and they said:
-They inspected this log, but there were no history about this log.
-They inspected HW log of server, but no problem found.
-They requested support result of OS vendor, but we do not have OS support becase we use CentOS and Ubuntu.
This logs were generated from vxlan driver of Linux kernel, but only generated in Intel's NIC.
https://github.com/torvalds/linux/blob/master/drivers/net/vxlan.c# L1320 linux/vxlan.c at master · torvalds/linux · GitHub
We are considering replace from Intel's NIC to Brodcom's NIC.
I hope this problem is solved as soon as possible.
woobee
Hi Woobee,
Thank you for the information. What is the Intel NIC model ? The one you provided on the thread are HP* NIC.
Sharon
Hi Sharon,
The HP NIC that I mentioned uses Intel Processor and Intel network addaptor driver.
Please see following summarized information:
1. HP 669280-001 Ethernet 1Gb 4-Port 366FLR Adapter
- Product Information: https://www.hpe.com/us/en/product-catalog/options/pip.specifications.hpe-ethernet-1gb-4-port-366flr-adapter.5288150.html
- Network Processor : Intel I350 Controller
- NIC driver and firmware information:
driver: igb
version: 5.3.5.12
2. HP 701525-001 ETHERNET 10GB 2-PORT 561FLR-T ADAPTER
- Product Information: https://www.hpe.com/us/en/product-catalog/options/pip.specifications.hpe-ethernet-10gb-2-port-561flr-t-adapter.5404516.html
- Network Processor : Intel X540 Controller
driver: ixgbe
Woobee
Hi Woobee,
Thank you for the clarification. It is best to contact HP* still as this is not Intel's network adapter but HP*'s, for OEM network adapter it is recommended to contact the OEM vendor.
https://www.intel.com/content/www/us/en/support/articles/000006628/network-and-i-o/ethernet-products.html?wapkw=oem+network
Please double check with HP* for customized drivers which are more suitable for the HP* network adapter.
Sharon
Hi Sharon
Even if the NIC is HP*'s, the chipset is Intel's. Therefore, the driver typically uses what Intel provides, such as ixgbe or igb.
In my case, I installed Ubuntu or CentOS and used automatically configured Intel drivers, such as ixgbe or igb.
So I contacted to Intel for driver support, rather than contact HP.
If you can no longer help me, I'll try to find another way.
Woobee
Hi Woobee,
Thank you for the information. The driver we have is generic version for Intel network adapter,
https://downloadcenter.intel.com/download/14687/Intel-Network-Adapter-Driver-for-PCIe-Intel-10-Gigabit-Ethernet-Network-Connections-Under-Linux-?product=59787
I can see you are using the latest version 5.3.5 from sourceforge as well. if you are using HP* network adapter, it is recommended to double check with them for customized driver that are suitable for your OEM HP network adapter.
Hope this clarifies.
Sharon
Hi Sharon,
I'll check this issue with HP.
If I need additional help, I'll post in Wired Communities again.
Thanks for your support.
Woobee
Hi Woobee,
You are welcome and feel free to update us.
Sharon
