Hi there,
I ordered a couple of x710's and received some pretty old ones from my dealer. They came with Firmware 4.37.
When I upgraded the first card, actually the upgrade procedure itself failed and now the card is not accessible at all anymore:
xxx@test01:~/XL710/Linux_x64$ sudo ./nvmupdate64e
[sudo] password for labadmin:
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.30.22.3
Copyright (C) 2013 - 2017 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [****-.....]
Num Description Ver. DevId S:B Status
01) Intel(R) Ethernet Converged Network 6.01 1572 00:007 Update not
Adapter X710-4 available
02) Intel(R) Ethernet Converged Network 4.37 1572 00:036 Update
Options: Adapter Index List (comma-separated), [A]ll, e[X]it
Enter selection:2
Would you like to back up the NVM images? [Y]es/[N]o: y
Update in progress. This operation may take several minutes.
Tool execution completed with the following status: An error occurred when updating a firmware module
Press any key to exit.
after rebooting I only get :
WARNING: TO AVOID DAMAGE TO YOUR DEVICE, DO NOT EXIT OR REBOOT OR POWER OFF THE SYSTEM DURING THIS UPDATE
Inventory in progress. Please wait [*+........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1572 07:00 Update not available
02) Intel(R) Ethernet Converged Network Ad 8086-1572 36:00 Access error
Tool execution completed with the following status: Communication with base driver failed. Please verify that the base driver is present
The cards look like authentic Intel Cards from 2014, so I wondered if there is a way of recovering them? ( I tried nvm 4.32 already without success )
best regards
Hello Regensensor,
Thank you for posting in Intel Wired Ethernet Communities. Please provide the product code from the Adapter label to verify this is the correct NVM version. Find the product code to look for in this https://www.intel.com/content/www/us/en/support/articles/000007060/network-and-i-o/ethernet-products... link. Are both the X710-T4 adapters not working after NVM update? If you have any questions please let us know.
Daniel D
Hi Daniel,
it's actually a DA4 card and the product code is as follows:
6805CA31F94C 484AD H49729-002
To me it looks like a genuine Intel card... old but original intel.
The other card is from another reseller that shipped with 6.01 already ( I wish I would have ordered all cards there ) .
I have two more of these adapters which shipped with 4.25... is there any guidance how to savely update them to a latest greatest nvm?
best regards,
hannes v.
Hello Regensensor,
Thank you, we have confirmed this is an Intel retail adapter. We will look into a solution for the corrupted NVM on the X710-DA4 at 4.37. For the two adapters at 4.25 please use the https://www.intel.com/content/www/us/en/embedded/products/networking/nvm-update-tool-quick-linux-usa... NVM update guide. Be sure that the latest drivers are installed prior to NVM update, and please update to NVM version 5.05 before updating to 6.01. Download the NVM update https://downloadcenter.intel.com/download/27064/Ethernet-Non-Volatile-Memory-NVM-Update-Utility-for-... here. Please do not hesitate to contact us with any questions. We will post an update on the corrupted adapter as soon as possible.
Daniel D
Hi Daniel,
thanks for your help so far. two more questions here:
1) why isn't the 6.01 nvm tool isn't spitting out an error message if you try to upgrade from below 5.05 to 6.01 and instead bricking the adapter?
2) So just to confirm once more before I brick anymore adapters:-)
NVM 4.25 -> 5.05-> 6.01 is supported and supposed to work?
correct?
hannes v
Hello Regensensor,
Thank you for the reply. Please update to 4.42 first then 5.05. You can find the compatible firmware versions for updates in the https://www.intel.com/content/dam/www/public/us/en/documents/release-notes/xl710-ethernet-controller... Feature Matrix see table 11 on page 19. The version 4.37 is not listed, so we will investigate that along with the restoration of the NVM. Please also include the distribution and version of Linux you are using. If you have any questions please do not hesitate to ask.
Daniel D
Hi Daniel,
I'm using of the shelf Ubuntu 16.04.5 right now:
test@srv3:~$ ethtool -i ens5f1
driver: i40e
version: 1.4.25-k
firmware-version: 4.25 0x800014cc 0.0.0
expansion-rom-version:
bus-info: 0000:24:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
e.g. the cards are usually used with dpdk (uio)
is there any hard constraint between driver version and nvm update?
hannes v.
Hi Daniel,
even following exactly your procedure to upgrade from 4.25 to 4.42 left the next adapter bricked.
I start assuming there is something wrong with that set of cards... I never had such issues before ...
best regards
hannes v.
labadmin@srv3:~/4.42$ tar xfz PRO_XL710NVMUpdatePackage.tar.gz
labadmin@srv3:~/4.42$ cd XL710/
labadmin@srv3:~/4.42/XL710$ cd Linux_x64/
labadmin@srv3:~/4.42/XL710/Linux_x64$ ls
Intel_Proprietary_License.pdf X710DA4_4p42_CFGID7p2_OEMGEN.bin XL710QDA2_gpio.txt XL710_4p42_KX_KX4_NCSI_CFGID1p0_Dual.bin XL710_4p42_QSFP_NCSI_CFGID4p5_Dual.bin XL710_X710_4p42_SFI_Backplane_MCTP_CFGID7p2_Dual.bin license.txt
Intel_firmware_license.txt XL710QDA1_4p42_CFGID4p0_OEMGEN.bin XL710_4p42_KR_KR4_NCSI_CFGID2p0_Single.bin XL710_4p42_QSFP_MCTP_CFGID4p0_Single.bin XL710_4p42_SFI_MCTP_CFGID7p2_Quad.bin XL710_X710_4p42_SFI_MCTP_CFGID7p2_Dual.bin nvmupdate.cfg
X710DA2_4p42_CFGID7p2_OEMGEN.bin XL710QDA1_gpio.txt XL710_4p42_KR_KR4_NCSI_CFGID2p4_Dual.bin XL710_4p42_QSFP_MCTP_CFGID4p5_Dual.bin XL710_4p42_SFI_NCSI_CFGID7p2_Quad.bin XL710_X710_4p42_SFI_NCSI_CFGID7p2_Dual.bin nvmupdate64e
X710DA4FH_4p42_CFGID7p2_OEMGEN.bin XL710QDA2_4p42_CFGID4p5_OEMGEN.bin XL710_4p42_KR_KX_NCSI_CFGID3p8_Quad.bin XL710_4p42_QSFP_NCSI_CFGID4p0_Single.bin XL710_X710_4p42_KR_KX_NCSI_CFGID0p5_Dual.bin file_license.txt readme.txt
labadmin@srv3:~/4.42/XL710/Linux_x64$ chmod +x nvmupdate64e
labadmin@srv3:~/4.42/XL710/Linux_x64$ sudo ./nvmupdate64e
NVMUpdate version 1.24.33.08
Copyright (C) 2013 - 2015 Intel Corporation.
Inventory in progress. Please wait [****+.....]
01) Intel(R) Ethernet Converged Network Ad 8086-1572 36:00 Update available
02) Intel(R) Ethernet Converged Network Ad 8086-1572 10:00 Update available
Select adapter(s) to be updated (only 'Update available' adapters may be selected
[(comma-separated adapter numbers) | All | eXit]: 01
Do you want to save a backup copy of current NIC images? [Yes | No]: yes
Update process in progress. Please wait [**........]
Tool execution completed with the following status: An error occurred when updating a module
labadmin@srv3:~/4.42/XL710/Linux_x64$ vi nvmupdate.cfg
Inventory in progress. Please wait [***-......]
Hi Hannes,
Thank you for sharing the latest result. Please do not update your other cards yet while we investigate your issue.
Does the other cards also has the same product markings that ends with H49729-002?
Vince T.
Intel Customer Support
yes, I can confirm the product marking...
I'll be standby waiting for your advise.
best
hannes
Hello Regensensor,
Thank you for confirming the product markings. Based on our investigation these are not Retail Intel adapters, but OEM adapters. We would recommend contacting the point of purchase to exchange these for the Retail adapters. Please let us know if you have any questions.
Daniel D
Hello Regensensor,
Following up to see if you were able to get the adapters replaced by the place of purchase. Let us know if you were able to get the retail version of the adapters, and how they work out. If you need any more assistance please do not hesitate to contact us.
Daniel D
Hello Regensensor,
Please let us know if you have any questions. Has the place of purchase been able to help you get the correct adapters?
Daniel D
Thanks Daniel,
quiet an argument but the cards have been returned to the dealer.
appreciated the proper support.
best regards
Hello Regensensor,
Sorry for the inconvenience. Glad you were able to return the adapters. Kindly let us know if you need any assistance with the new adapters. Please do not hesitate to contact us with any questions.
Daniel D
