FPGA Intellectual Property
6670 Discussions
A problem with runing the alt_dspbuilder_createComponentLibrary
Error in block : Arria_II_GX_EP2AGX125_alteradspbuilder2/4-Bit DIP Switch
Java exception occurred:
com.altera.dspbuilder.simulation.MaskInitialisationException: Exception in block 'Arria_II_GX_EP2AGX125_alteradspbuilder2/4-Bit DIP Switch'
at com.altera.dspbuilder.simulation.Mask.init(Unknown Source)
Caused by: java.lang.NullPointerException
at com.altera.dspbuilder.simulation.Model.getAbsoluteTestbenchPath(Unknown Source)
at com.altera.dspbuilder.simulation.Model.getValidIOFile(Unknown Source)
at com.altera.dspbuilder.simulation.Model.getSaltFileForBlock(Unknown Source)
at com.altera.dspbuilder.simulation.blocks.IOBlock.getIOFile(Unknown Source)
at com.altera.dspbuilder.simulation.blocks.IOBlock.getIOFileNames(Unknown Source)
at com.altera.dspbuilder.simulation.blocks.IOBlock.access$000(Unknown Source)
at com.altera.dspbuilder.simulation.blocks.IOBlock$IOBlockLibrary$1.eval(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl.call(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._factor(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._term(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._expr3(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._expr2(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._expr(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._cond(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._root(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl._top(Unknown Source)
at com.altera.etc.minieval.MiniEvalImpl.evaluate(Unknown Source)
at com.altera.dspbuilder.simulation.Block.calculateExpressionParameters(Unknown Source)
... 1 more
Error executing : save_system('Arria_II_GX_EP2AGX125_alteradspbuilder2', 'Arria_II_GX_EP2AGX125_alteradspbuilder2');
Previous command was : set_param('Arria_II_GX_EP2AGX125_alteradspbuilder2/PB1', 'Position', [160 312 200 358]);
Error using save_system (line 38)
An error occurred during a callback while saving
'C:\altera\12.1sp1\quartus\dsp_builder\bin\mdllibrary\Arria_II_GX_EP2AGX125_alteradspbuilder2.slx'.
The previously saved version of this file (if any) has not been changed.
Error in save_system (line 38)
throw(e);
Error in
C:\altera\12.1sp1\quartus\dsp_builder\bin\matlab\alt_dspbuilder_createComponentLibrary.p>alt_dspbuilder_createComponentLibrary
(line 28)
thanks very much ,it may be the problem when save as the .slx file.
DSP Builder 12.1 doesn't support slx files. You could change your MATLAB preferences to make mdl files the default until that issue is fixed.
