FPGA Intellectual Property
6669 Discussions
ALTLVDS pins io standard
hi,
I am using ALTLVDS megacore for serialization and deserialization.
the serializer has tx_out : OUT STD_LOGIC_VECTOR (0 DOWNTO 0)
and the deserializer has rx_in : IN STD_LOGIC_VECTOR (0 DOWNTO 0)
when i assign the io standar for these pins as LVDS, the pin planner creates tx_out(0)n & rx_in(0)n. when i assign these pins to diffential pain then during fitter i get the below error
Error: Found two LVDS low registers instead of one!
is am i connecting pins correctly or do i have to add an alt_inbuff_diff & alt_outbuff_diff?
Can you post your current pin assignments either from your QSF or by exporting a TCL from the pin planner?
Jake
It's sufficient to assign LVDS IO standard to the logical pin. The location must be the positive pin of a differential pair. The negative pin is also displayed in the Pin Planner tool, but you don't need to assign it anyway. You can even delete the negative pin entry from the Pin Planner list. The handling of negative differential pins isn't actually consistent throughout the different Quartus tools, it seems confusing in part.
pls. find the archived project attached, i tried the methods sugessted...but did not work
quartus 9.1sp1 fitter error
Error: Found two LVDS high registers instead of one!
for this piece of code generated by megawizad
// synopsys translate_off
initial
dataout_h_reg = 0;
// synopsys translate_on
always @ ( posedge clock)
dataout_h_reg <= ddio_h_reg;
initial
dataout_l_latch = 0;
always @ ( negedge clock)
dataout_l_latch <= ddio_l_reg;
initial
dataout_l_reg = 0;
dataout_l_reg <= dataout_l_latch;
initial
ddio_h_reg = 0;
ddio_h_reg <= datain;
initial
ddio_l_reg = 0;
ddio_l_reg <= datain;
assign
dataout_h = dataout_l_reg,
dataout_l = dataout_h_reg;
endmodule //RxLVDS_lvds_ddio_in
The problem is, that Quartus doesn't accept this port definitions (1-bit arrays):
RxData : in std_logic_vector(0 downto 0); -- IP data transmit TxData : out std_logic_vector(0 downto 0); -- IP data transmit
Define the ports as std_logic, use additional wire signals and assign them to the Rx/Tx IP:
signal RxData0 : std_logic_vector(0 downto 0); signal TxData0 : std_logic_vector(0 downto 0); ... TxData <= TxData0(0); RxData0(0) <= RxData;
Then your code compiles without problems.
I still get those fitter errors if i assign "LVDS" IO standard to RxData & TxData, i am making it sure that pin assignments are done correctly in pin planner
No idea how you achieve it, as said, the design compiled correctly (with Quartus 9.0) after changing the top level to the version, I posted above. I'll send the complete design, too.
Thank you very much...the project archive which u send is getting compiled.....just wondering why it did not compiled in quartus 9.1SP1
thanks again for the help
FvM,
one thing i have observed in ur project is that u have assigned pin locations to the internal signals i.e. Rx_Data[0] and Tx_Data[0], this is some thing i have learned new.
But I didn't assign them intentionally. They have been left from your design. I see now, that Quartus did not assign LVDS IO-standard for the renamed pins. If I assign it anew, the error reappears. In other words, my suggestion does not work.
It seems to me, that something is wrong with the newer alt_lvds MegaFunction, or with the way you invoked it. I'll try to recreate the respective module and see, if it can be connected to LVDS IO pins as I do since many years.
I found the reason, why Quartus doesn't accept your design.
You connected four RxLVDS instances to the same pin. This doesn't work, because Quartus needs to implement the double data rate registers as IO registers. So there can be only one RxLVDS MegaFunction for each pin.
P.S.: You can disable the requirement to use IO-registers by removing the Altera synthesis attributes LVDS_RX_REGISTER=LOW and LVDS_RX_REGISTER=HIGH from RxLVDS_lvds_rx.v, which resides as a copy in the db directory. Then Quartus can use regular LE registers, but the timing will become worse, of course.
