FPGA Intellectual Property
6673 Discussions
AVALON_MM interface of TSE
Hello guys,
In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,but it failed when I simulated with my own configuration modle.
My question is wether the AVALON_MM can be read or write without NiosII.:confused:
Yes it can, you can drive the signals yourself. Be sure to use the waitrequest signal as specified in the Avalon specification.
--- Quote Start ---
--- Quote End ---
daixiwen,
First,thank you for your reply.
I have write my own configuration module to config the registers.When I simulate the module with TSE,I see the waitrequest signal is always high.Due to this,I can't read or write any register.According to your opinion,what's the proplem.
I appreciate your help!!;)
the name of the signal explains this.
waitrequest .... request to wait !
if this is set to 1 then a master must obey this and wait until it is released.
a master starts the transfer and sets the signals and a slave can assert waitrequest if the slave is not able to finish the transfer with this clock cycle. if the slave ha done his job (after ??? cycles) then he releases waitrequest to signal the master the transfer is finished.
so as long as waitrequest is set to 1 a slave is not ready and data is not valid or computed.
but it should go to 0 or it would be an infinite wait. as master who receives a wait is stalled.
First, be sure that you run the simulation for an enough long time. The component may need lots of cycles to initialize.
Second, check that you provide all the required clocks, for the Avalon MM interface, but also for the Avalon Streams. You may even need to provide an MII transmit clock. There is probably lots of clock domain crossing logic in the TSE, and failure on one clock could lock the component.
Thanks,michael.I know the meaning of waitrequest for master .What I don't understand is why it is always high in whole simulation process.Whatever,thank you for your reply!!!:D
daixiwen,I run simulation for 10us.Is it not enough long? Besides,I have give all clock signal to other interface.However,I will check it again,thank you~~:)
Is your reset or clock stuck?
Jake
--- Quote Start ---
Jake
--- Quote End ---
I set right value of clock and reset.I made mdc output and found it was right.But waitrequest was always 1.
Is there other proplem may cause the unnormal phenomenon?
Thanks,Jake.:)
P.S.:the attachment is my project,could you help me to check it?
Be careful that the reset signal on the MAC is active high, not low.
Altera provides an independent test bench for the TSE mac (see chapter 5 of the documentation). Can you run it and check the differences in the signals with your test bench?
--- Quote Start ---
--- Quote End ---
How to run the test bench?Is modelsim used?:confused:
Isn't it generated by the megawizard?
And yes, it probably needs to be run in Modelsim.
Sorry for bringing up this old thread but I have the same problem here with a tse_mac that was originally used with a NIOS and shall now be used without one. I also have the problem, that the waitrequest signal is never deasserted. I simulated for > 18 ms so I do not think it is an initialization delay or something like that.
flint
Do you provide all the clocks (including the Avalon streams and the MII interface)?
Did you check the polarity of the reset signal?
Do you send a reset pulse at the beginning of the simulation?
I think I connected everything I should:
Clocks:
clk
ff_rx_clk
ff_tx_clk
rx_clk
tx_clk
are all connected to the same 125 MHz clock.
I provide a reset on simulation start for 100 ns, after reset goes low the mdc clock output starts so I think this is correct.
flint
What operation do you do, when you have the wait request signal asserted? Is it the first one?
The waitrequest signal is high right from the start. I do no operation. I tried to read out the version register and write and read the scratch register but this does not work (as one might expect with the waitrequest signal high).
flint
Did you try the testbench generated by the megawizard, to see if there is any difference with your test?
sorry for not posting in the previous week, I was on vacations.
Indead your tip to compare against the provided testbench brought me to the solution: I had a misconception over the semantics of the waitrequest signal, it is high per default, then you start a transaction (read or write) and on the end of this transaction the signal goes low for one clock cycle to signal that you can start the next transaction. Now I can write and read the scratch register with arbitrary values so I assume register access works.
Maybe my fault because I did not read the Avalon-MM spec, only the Avalon-ST.
Thanks for your help,
flint
I am also having trouble with waitrequest high...
I am just trying to write the scratch register (address 8'h01) with 32'haaaaaaaa but not successful as waitrequest signal is high throughout simulation :(..
I am providing 50 MHz clk for Avalon-MM interface and 125MHz clk for ff_tx_clk, ff_rx_clk, tx_clk, rx_clk.
Also when Analysis and Elaborating the project using Quartus II 10.1, got the warning "Warning (10236): Verilog HDL Implicit Net warning at altera_tse_rx_stat_extract.v(112): created implicit net for "reset_rx_clk"". How to resolve this warning as it is in encrypted file..
Sawaak
Did you reset the TSE first? Did you check the polarity of the reset signal?
--- Quote Start ---
--- Quote End ---
Yes, I have applied the reset and the polarity is high.
regards,
sawaak
