FPGA Intellectual Property
6670 Discussions
AVS_AES IP-Core from OpenCores
I am working on a project for my university where I need to encrypt AES. I want to use the AES 128/192/256 ( ECB ) Avalon-MM Slave from Thomas Ruschival which can be found at http://opencores.org/project,avs_aes (http://opencores.org/project,avs_aes). As development board I am using a DE2-115 and I am working with Quartus 10.1sp1.
If I implement the core and try to run the example c-code, that comes with the core I just get 0x00,0x00,0x00,0x00 out as result (I tried to debug and look into it quite some time). Does someone has a running example he would share with me?
Thanks, Peter.
--- Quote Start ---
Thanks, Peter.
--- Quote End ---
Any joy with this Peet?
I've been fouling around with this the last few days, no joy as such..
I converted vhdl to BDF and connected up ios etc. Doesn't want to compile for me at the moment!
