FPGA Intellectual Property
6673 Discussions
Agilex "support logic" gives failed synthesis rules with medium severity
alexislms
Valued Contributor I
The Agilex's support logic gives failed synthesis rules with medium severity.
RES-30133 - Embedded Memory Blocks with Initialized Content That Might be Modified Before the FPGA Enters User Mode
agilex_xcvr__tiles|z1577a_x0_y0_n0__reset_controller|x_f_tile_soft_reset_ctlr_sip_v1|x_ftile_reset|rst_ctrl|nios0|nsm|regfile_b|auto_generated|altera_syncram_impl1|lutram*
agilex_xcvr__tiles|z1577a_x0_y0_n0__reset_controller|x_f_tile_soft_reset_ctlr_sip_v1|x_ftile_reset|rst_ctrl|nios0|nsm|scr_ram|auto_generated|altera_syncram_impl1|ram_block*
agilex_xcvr__tiles|z1577a_x0_y0_n0__reset_controller|x_f_tile_soft_reset_ctlr_sip_v1|x_ftile_reset|rst_ctrl|nios0|nsm|regfile_a|auto_generated|altera_syncram_impl1|lutram*
agilex_xcvr__tiles|z1577a_x0_y0_n0__reset_controller|x_f_tile_soft_reset_ctlr_sip_v1|x_ftile_reset|altera_syncram_component|auto_generated|altera_syncram_impl1|ram_block*
RES-30132 - Registers May Not Be Properly Reset
agilex_xcvr__tiles|z1577a_x0_y0_n0__reset_controller|x_f_tile_soft_reset_ctlr_sip_v1|divided_osc_clk
ShengN_Intel
Below are the messages from internal:
This is a false warning. It has been reported multiple times already. We are working with the Design Assistant team to suppress it, but we are not going to change the SRC to try to remove it.
I am working with the Design Assistant team to provide a way to disable this error in the SRC RTL. Right now, this cannot be done.
Check the attached picture. Can just ignore them for now.
Sheng
ShengN_Intel
Sheng
