FPGA Intellectual Property
6673 Discussions
Agilex5 temperature sensor interface sample code?
zener
I have found documentation on the location of the temperature sensors and that I might need to use the MailBox IP, but nothing specific on how to do it.
Are there any example designs available for temperature readout from e.g. an AXI4Lite or Avalon master?
Farabi
You may refer to : https://www.intel.com/content/www/us/en/docs/programmable/683373/current/design-example.html
This is for Agilex 7 , but the mailbox client is same for both. You can use this design example and change the device and recompile.
regards,
Farabi
