FPGA Intellectual Property
6670 Discussions
AltPll Dynamic phase shift state machine
Hi everyone,
I am trying to implement a design for generating a dynamic phase shift clock output. I am using cyclone III device for my design. I have gone through the documentation to implement dynamic phase shift ( http://www.altera.com/literature/an/an507.pdf ) I found a statemachine implimentation description to controle the parameters of the pll. I have implemented the statemachine as described in the document but it doesn't seem to work. If any body implemented the statemachine,could you please help me .
sarat
Did you check in hardware or gatelevel simulation? If in hardware, can you show a signaltap recording of the relevant signals?
The statemachine is working fine. I have tested it with signal tap.below you find the code.
library ieee;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all ;
entity dynamic_input is
port (
clk : in std_logic ;
choose_op : in std_logic_vector ( 1 downto 0 ); -- "01" to shift down the phase,"10" to shift up the phase and others no effect
phase_counter_sel_in : in std_logic_vector ( 2 downto 0 );-- for selecting output clock to be shifted
phase_counter_sel_out : out std_logic_vector ( 2 downto 0 );
phase_up_down : out std_logic ;-- when '1' shifts phase up '0' shifts down
phasestep : out std_logic ;--to enable phase shift process
phasedone : in std_logic ;
--scan_clk : out std_logic ;
--state_out : out std_logic_vector (1 downto 0 )
end entity dynamic_input;
architecture behaviour of dynamic_input is
type state is ( init , phase_up , phase_down , wait_up , wait_down , wait_shiftend , wait_phasedone );
signal pr_state : state ;
signal next_state : state := init ;
begin
--scan_clk <= clk ;
phase_counter_sel_out <= phase_counter_sel_in ;
process ( clk )
begin
if ( clk = '0' and clk'event ) then
pr_state <= next_state ;
end if ;
end process ;
process ( pr_state )
begin
case pr_state is
when init =>
--set initial values to the dynamic parameters--
phasestep <= '0' ;
phase_up_down <= '0' ;
if ( choose_op = "10" ) then
next_state <= phase_up ;
elsif ( choose_op = "01" ) then
next_state <= phase_down ;
else
next_state <= init ;
end if ;
when phase_up =>
phasestep <= '1' ;
phase_up_down <= '1' ;
next_state <= wait_up ;
when phase_down =>
phasestep <= '1' ;
next_state <= wait_down ;
when wait_up =>
phasestep <= '1' ;
next_state <= wait_phasedone ;
when wait_down =>
phasestep <= '1' ;
when wait_phasedone =>
if ( phasedone = '0' ) then
phasestep <= '0' ;
next_state <= wait_shiftend ;
end if ;
when wait_shiftend =>
if ( phasedone = '1' ) then
end if ;
end case ;
end process ;
end behaviour ;
