FPGA Intellectual Property
6670 Discussions
Need some advices on designing multiple DMA in a PCIE bridge chip
Hi everyone,
I'm now starting to do a PCIE bridge with video and audio DMA.
My final goal is to have 4 video interfaces (BT1120) and at least 4 audio interfaces (I2S) as the data input of this bridge.
For now, only one video interface and one audio interface have been done in my design as a preliminary test.
For the video part, I have the following design for DMA transfer from BT1120 to allocated memory on PC.
Clocked video input IP --------> DMA writer from mSGDMA --------> txs port in PCIE HIP
For the audio part, I write a module named "I2S module" to convert I2S to avalon st.
The design for DMA transfer from I2S to allocated memory on PC looks like:
I2S module --------> FIFO --------> DMA writer from mSGDMA --------> txs port in PCIE HIP
Now, here comes my three questions:
1. Multiple DMA arbitration problem:
If I enable both video and audio DMA and the input video is 1080p60, how do I ensure the video DMA can generate 60 interrupts in a second?
From what I understand, this is a multiple master to one slave design on avalon mm bus and interconnection fabric should do the arbitration automatically. Can I assign a higher priority to the video DMA part?
2. Resource sharing problem:
For my current design, each video or audio interface requires a DMA writer and a DMA dispatcher.
Therefore, in order to achieve my final spec, my design will need at least 8 DMA writers and 8 DMA dispatchers.
It's kind of waste because these 8 DMA writers and 8 DMA dispatchers cannot work at the same time.
It would be better if my design becomes as follows:
Clocked video input IP--> MUX --> DMA writer from mSGDMA --> txs port in PCIE HIP
I2S module ---> FIFO --->
The selection signal of MUX may come from some sort of priority arbitrator circuits.
For this kind of design, how should I do to avoid data loss? Increase the size of FIFO? Add a FIFO after clocked video input IP?
3. FIFO size:
Is there a good way to decide the required size of FIFO?
For now, I just use try & error to find a suitable size of the FIFO.
Any advice and idea are welcome to my questions. Thanks.
