FPGA Intellectual Property
6670 Discussions
Altera JESD204B IP Core - Sequence of operations
Hi!
I develop an Altera JESD204B IP core based system.
I use reference design https://documentation.altera.com/#/00024250-AA$NT00073969
Cyclone V GT development board and DEV-ADC34jXX http://dallaslogic.com/prod_dev-adc34j/
I configure clocks and adc via SPI with the same parameters as JESD core.
LMF 442
N 12
NP 12
K 20
Fsampling 50 MHz
Device clock 100 MHz
Sysref 2.5 MHz
Link clk 25 Mhz
Frame clk 50 MHz
Basing on the reference design I perform the sequence of operations:
1. Init clk ic (See the Device clk and sysref)
2. Reset via reset_sequencer as it done in Arria based reference design, got core_pll_locked and xcvr_ready
3. Assert xcvr | link | frame resets
4. Configure adc
5. de-assert resets and clear error status regs
System does not switch to ILA state and remains in CGS
If I set in the 4th step (csr_sysref_singledet | csr_sysref_alwayson) I get SYSREF_LMFC_error.
What steps do I need to perform to get it working?
Thanks in advance!!!
