FPGA Intellectual Property
6673 Discussions
JESD data rate Qsys / Link Clock
Hi there,
I've got 2 questions related to how to setup my JESD Qsys IP for the TI ADS54J60 ADC.
  • Is it correct to fill-in a data rate of 5 Gbps in the Qsys window with the configuration as shown below?
  • (1 Gsps * 2 ADCs * 16 bits * (10/8))/ 8 lanes
  • Is it correct to calculate the link clock as: 5 Gbps/40 = 125 MHz?
  • I don't really understand where this 40 is coming from/based on.
Thank you for your help.
With kind regards,
Patrick
Sample frequentie
Gsps
Samples per second
Data rate
Gbps
Raw data rate per link
Number of lanes per converter device
Number of converters per device
Number of octets per frame
Samples per converter per frame
16
Number of conversion bits per converter
N'
16
Number of transmitted bits per sample
32
Number of frames per multiframe
CS
Number of control bits per conversion sample
CF
Number of control words per frame clock period per link
HD
High density user data format
LMFC
16
Link clock counts
Local multiframe clock
Hi!
I faced the similar problem)
1. If we consider Altera IP Core the data rate is supposed to be the data rate per EACH lane (NOT total data rate per all link lanes).
2. Link clock == Data rate (per each lane)/40
User Guide, p 4-19
"The timing reference for the JESD204B IP core.The
link clock runs at data rate/40 because the IP core is
operating in a 32-bit data bus architecture after 8B/
10B encoding."
As far as I understood link clock == 125MHz, frame clock == 250MHz
Best regards!
