FPGA Intellectual Property
6670 Discussions
Altera transceiver bits swapped
Hi all.
I'm working on a simple transceiver loopback test using a stratixIV GX development kit.
I instantiated a simple ALTGX function in basic (PMA direct) mode, and i attached the altera loopback connector to the HSMC board.
The reset sequence was done according to the reference documentation .
The transceiver is fed by a simple counter, but on the receiver side i see the counter with the bits misaligned (eg tx: ABCDEF rx: EFABCD).
Is this a known issue?What can I do to debug the design?
I can provide as much info as you need, even the whole design.
Thanks in advance
Marco
this isnt a bug, you need to bitslip the data until it is aligned. generally there is a training sequence that is either spec'ed by the protocol, or is user specific.
Thanks a lot dwesterg,
So for a "raw" transmission i need to implement myself a synch word and a FSM to realign the received data, right?
But if i use a protocol (eg basic x4) i see in the signaltap anlyzer that the bits keep swapping.
let's say the synch word is "0101111100", is it sent automatically or do i need to inject it periodically in the data?
Thanks again!
Marco
(EDIT)
the answer was yes, i need to inject the synch word and use an optional port to tell the transceiver when to realign.
tnx
