FPGA Intellectual Property
6673 Discussions
Arria 10 JESD204B Interoperability Reference Design timing issues
mem
IP core Arria 10 JESD204B AD9144-AD9625 Interoperability Reference Design uses the following attribute for register duplication :
altera_attribute of normal : architecture is "-name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON;   ....  "
Quartus 19.1 ignores the register duplication attribute and we cannot get the required timing. All the failing paths have the following node as a starting point :
u_jesd204b_ed_qsys|jesd204b_subsystem_0|rst_controller|alt_rst_sync_uq1|altera_reset_synchronizer_int_chain_out
We tried several ways to convince Quartus to automatically duplicate registers in these paths, but it keeps ignoring all settings for register duplication.
Is there an attribute suitable for Arria 10 for register duplication?
KennyTan_Altera
Any reason that you want to duplicate those register? Are this for timing closure? If yes, can you send us a screenshot of the timing violation.
Usually you can see the duplication failure in the fitter/synthesis reports. Can you check on it? it will show the failing reason. But I think this feature only exist in the latest Q20.4, can you upgrade your Quartus to latest version?
KennyTan_Altera
any update?
mem
At this point we have tested every design provided by Intel for jesd204b for Arria10
and we are a bit confused. We are interested to purchase a license for jesd204b from
Intel.
Any support is appreciated,
Thank you.
KennyTan_Altera
You may contact your local sales distributer to purchase any license. You may find it here:
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
KennyTan_Altera
Since this thread had been answered, we shall close this thread. If you still need further assistance, you are welcome to post a response within 15days or open a new thread, some one will be right with you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
