FPGA Intellectual Property
6662 Discussions
Arria V - LVDS output performance
Mircea
My 5AGXFB7H4F35C4 receives a 125MHz, ideal reference clock.
Using the internal PLL, I want to generate a 500MHz sampling clock for controlling 8 ADC chips.
1. What is the maximum clock frequency coming out of this device in LVDS?
2. What would be the jitter?
3. What setting should I use, and what output pin for best performance?
I also want to send a 2ns wide SYNC pulse on 8 outputs.
4. What would be the skew between the 8 outputs?
5. What is the minimum pulse width for LVDS outputs?
6. What setting should I use, and what pins for best performance?
7. Where can I read these specs?
Please, don't tell me to just read some 10,000-page data sheet.
Mircea
EngWei_O_Intel
Hi Mircea
Can you check if Table 40 of below doc is what you are looking for?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-v/av_51002.pdf
For output pins, depends on clock or IO types, you can refer to below link:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/arria-v/pcg-01013.pdf
And map your device to the pin out file:
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
For skew handling, you can refer to timing constraint chapter 1.5.4 of https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altlvds.pdf
Eng Wei
Mircea
Hi Eng Wei,
You only answered question 7.
If you don't know the answers for questions 1 to 6, please ask someone who knows, and get back to me.
Here are my questions again:
1. What is the maximum clock frequency coming out of this device in LVDS? It's not through the ALTLVDS.
3. What setting should I use, and what output pin for best performance? Please, give example of pin number and setting.
6. What setting should I use, and what pins for best performance? Please, give example of pin number and setting.
Mircea
EngWei_O_Intel
Hi Mircea
If you aren't using LVDS SERDES IP, then you shall refer to PLL spec (Table 36) in the same document.
For differential signal input/output pins, you should always pick from DIFFIO_RX* or DIFFIO_TX* from the list, depends on which IO banks you are using. The min pulse width depends on the max freq achievable in your design.
For clock skew specific question, I would suggest you to file another request and timing expert will be able to assist you.
Eng Wei
EngWei_O_Intel
Hi Mircea
I hope you are doing well. Since there is no further question, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
