FPGA Intellectual Property
6670 Discussions
Asynchronous/ controlling clock port of a flipflop
Hello All,
I am wondering if i can explicitly define a clock port to a flip-flop(D-FF or T-FF). The functionality should be like this, I need to sample a date input with respect to a positive-rising edge of a control signal. I am aware that you can use enable port in the flip-flop but i need to sample the data line exactly at positive rising edge.
Dilip
A flip-flop samples the data input always exactly at the positive (or negative) rising edge of it's clock input. It's no problem to use a control signal other than the system clock as clock for a FF, but then it's output is asynchronous in respect to the system clock and has to be synchronized.
I get that. I want to know how to use a control signal other than the system clock as clock for a FF. As i can see the clock port is implicit.
Oh I am sorry. All these things am talking about is concerned to Alters DSP builder on Simulink.
