FPGA Intellectual Property
6669 Discussions
HDL-master for SDRAM controller
I'm trying to connect my own hdl-master with DDR SDRAM Controller (MegaCore) for writing in off-chip memory. This UG (http://www.altera.com/literature/ug/ug_ddr_sdram.pdf) doesn't contain any information about basic avalon signals (write,writedata and etc.).
How I must to control this signals in my master? How the address space is allocated in controller?
For example, I attempted to write word of data in base controller address (without any offset) but it doesn't produce the expected result.
Thanks for any help.
The avalon specification is here (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf).
Writing to the base address should work. Just remember that on an avalon master interface, the address is byte aligned, and not word aligned like on a slave interface.
Somewhere in this tutorial .zip file are a bunch of components written for Qsys (and SOPC Builder), two of which are read and write masters. They should give you a good idea how to structure your logic: http://www.altera.com/support/examples/design-entry-tools/qsys/exm-qsys-tut.html (http://www.altera.com/support/examples/design-entry-tools/qsys/exm-qsys-tut.html?)
