hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
FPGA Intellectual Property
Avalon On chip Fifo
Hi all,
i'm having trouble with avalon Fifo core (dual clock mode).
I have a simple FSM that grabs data from a fifo(1) and then transmit the response to another fifo(2) but nothing is written as read level is 0.
But, if i write 3 times the same data in fifo(1) i get one response in fifo(2).
well i think i missed something there...
notes : interrupts are disabled, Almost empty = 1
init_fifos_in(); init_fifos_out(); init_fifos_in(); init_fifos_out(); altera_avalon_fifo_write_fifo(FIFO_PC_TO_DIF_IN_BASE, FIFO_PC_TO_DIF_IN_CSR_BASE, 0x00004005); altera_avalon_fifo_write_fifo(FIFO_PC_TO_DIF_IN_BASE, FIFO_PC_TO_DIF_IN_CSR_BASE, 0x00004005); altera_avalon_fifo_write_fifo(FIFO_PC_TO_DIF_IN_BASE, FIFO_PC_TO_DIF_IN_CSR_BASE, 0x00004005); printf("pio read = x%x\n", IORD_ALTERA_AVALON_PIO_DATA(PIO_0_BASE)); if(altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE)>0) { printf("altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE) = %d\n",altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE)); while(altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE)!=0) { printf("fifo read = x%x\n", IORD_ALTERA_AVALON_FIFO_DATA(FIFO_DIF_TO_PC_OUT_BASE)); } } }
status initializing fifo = 0 pio read = x4005 altera_avalon_fifo_read_level(FIFO_DIF_TO_PC_OUT_CSR_BASE) = 1 fifo read = x30c30c30
problem solved, fsm did not work properly (signal tap), although it was ok in simulation...
