FPGA Intellectual Property
6670 Discussions
CVI directly connected to CVO
In SOPC, the CVI --> Terminator and TPG --> CVO, the input format can be recognized correctly and output work correctly.
Then the CVI --> CVO, and the CVO format is same as the CVI, but the CVO has no output.
Does it possible to connect the CVI and CVO directly?
Regards.
yes, i've used TPG > CVO > CVI > CVO for debugging (around 9.1 if it makes a difference)
Thanks, now the CVI -> CVO works.
But CVI always overflow and CVO always underflow, I guess something wrong in clock.
