FPGA Intellectual Property
6673 Discussions
CXL Base Hard IP configuration
JL_P
The questions are as follows: community.intel.com/t5/FPGA-Intellectual-Property/CXL-Base-Hard-IP-configuration/m-p/1497136#M27707 I also want to know if the CXL Base Hard IP supports CXL.Mem. Thanks
RongYuan
The Base HIP example design does not support CXL.Mem due to the lack of request handler.
Rong
JL_P
Hi
    I know the example design dose not support CXL.Mem, because the code of the example does not have the functionality to handle cxl.mem.
   I'd like to know if Base HIP supports the cxl.mem functionality. I've noticed that the CPI interface has corresponding cxl.mem signals. If I parse and process the cxl.mem signals externally, can I then implement the cxl.mem functionality?
JL_P
Hi
RongYuan
Since the CPI is there, it does provide the possibility to do CXL.mem. Unfortunately after few days of searching, I couldn't find more support doc and use case related to this.
Rong
