FPGA Intellectual Property
6673 Discussions
Can PCIe Hard Core IP configured as gen3x8 interface, 256 bits, 256Mhz, with Avanlon-MM with DMA work on 10AS066N3F40E2SG?
HTong1
Can PCIe Hard Core IP configured as gen3x8 interface, 256 bits, 256Mhz, with Avanlon-MM with DMA work on 10AS066N3F40E2SG? The TimeQuest showd a lot of timing violations within the IP, some of which are as large as 5ns. Thanks.
SengKok_L_Intel
Hi, Yes, A10 support Gen3x8 with 256bit interface. Please refer to table 10 in the link below for the recommended speed grades https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avmm_dma.pdf Regards -SK
