FPGA Intellectual Property
6670 Discussions
Can't find clock output pins of DDR
I have a NiosII design that contains a ddr_sdram core. When I moved from Quartus 9.0 to 9.1, it started giving me the following error:
Error: DDR Post compile timing analysis failed Error: Couldn't find the clock output pins. Stop.
On page 44 and 45 of http://www.altera.com/literature/rn/rn_ip.pdf it states a solution to my problem:
Workaround Make the following two assignments: ddr_pll_stratixii:g_stratixpll_ddr_pll_inst Preserve PLL Counter Order On ddr_pll_stratixii:g_stratixpll_ddr_pll_inst|altpll:altpll_component|_clk3* Global Signal Global Clock Replace the file names of the PLL with those in your DDR SDRAM controller design.
Where/How do I make the two assignments? and Where/How do I replace the file names?
I think I am having a brain fart.
-Ben
make the assignments in the assignment editor.
The fitter report should provide a name for your actual PLL instance.
