FPGA Intellectual Property
6670 Discussions
Create a DDR3 memory through ALTMEMPHY wizard
Good Day everyone!
I have a troubles in understanding how to create a megacore DDR3 which must be based on ARRIAIIGX family's IC! I plan to use a memory like MT41J64M16JT-15E (2*x16bits) & EP2AGX65DF25C5 FPGA.
I'm sure that is this forum have someone who can help & explain how to create without a mistakes "step-by-step":)
Roman.
So there are no examples for Arria II GX board? These are the best references.
Thanks for the answer, Dear Socrates!
Yes of course, Altera has the best on-line tranings & I like that! But most of examples based on UniPhy ... I must use the ALTMEMPHY! Besides the traning http://www.altera.com/education/training/courses/omem1110 based on UniPhy & therefore there are not so full-valued for me!
Also I would be glad if you explain me how to place x32 DDR3 on the 3A,4A or 7A, 8A banks of EP2AGX65DF25C5?
I tried to create the same project like this, but unfortunately I got a mistakes, I supose that I'm doing something wrong ...
Roman.
DDR, DDR2 and DDR3 memory devices has to be interfaced to special (dedicated) FPGA pins. Run Pin Planner and enable showing of DQ/DQS groups - You'll see which pins can be used as data pins, which pins must be DQS, etc... Also some banks are capable of faster rates, some are not, but I am not sure about Arria II, since I use Cyclone III.
