FPGA Intellectual Property
6668 Discussions
Creating a Custom Hex File
UserID4331231
I need help on How to create a customized Hex file.
I have a config space of 8K (Memory IP) . for which we have derived the "initial values", these values are not a fixed pattern or sequence. And over time these initial values may change.
With quartus hex file creation tool I can only initialize hex file with simple patterns, and writing 8k values manually is impractical.
I have a csv file established for derived "initial values", and its format is as following
#8 byte offset in Decimal , #value in signed decimal, #comment
0 , 15,
8 , 39,
16, 158,
24, 59,
Comment column can be ignored, its for readability of the file.
if a offset is not present, it need to assign a default value (lets say 0) .
I can easily write a script in python or C to read this csv file and dump a file with .hex extension. But i don't know Hex file encodings.
can you help me to find solution where I can generate .hex file with custom values for every offset?
attaching example.csv for the reference.
attaching a csv file for the reference
RichardTanSY_Altera
I believe this is what you're looking for. The Hexadecimal File (.hex) Definition webpage provides the hex format (its code and definition), which may help you write a script to generate the hex file automatically.
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#reference/glossary/def_hexfile.htm
If you're interested, there's also a definition for Memory Initialization File (.mif).
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#reference/glossary/def_mif.htm
Richard
RichardTanSY_Altera
Hi OP,
Any update on this?
Do you able to resolve the issue?
Richard Tan
