FPGA Intellectual Property
6669 Discussions
Cyclone 10GX PCI express without clk_user any solution ?
manu-solystic
I have a prototype design with a Cyclone 10GX
I want to use the PCI express , but the clk_user is not connected
And if i read the documentation about the PCI express with cyclone 10Gx , this clock seems to be mandatory
But on my design, it's not possible to connect the CLK_USR  (The pin is not accessible)
Does any have a suggested solution, to have a a PCI express working
With the use of a other clock connected to the FPGA.  with an internal connection.
I have a 100Mhz LVDS clock connected to the Cyclone 10GX, and I have also a 25Mhz HCMOS clock connected to the FPGA
These clock are used in the Cyclone 10GX design
Thanks for any answer
Manuel Ribeiro
manu-solystic
So I understand that the only solution is to connect a clock on the clkuser pin
So you can close this ticket
regards
Wincent_Altera
Thanks for reaching, I will close this thread as duplicate.
Moving to https://community.intel.com/t5/forums/forumtopicpage/board-id/programmable-devices/message-id/88912#M88912
Wincent_Intel
Wincent_Altera
Can I know which document you are referring to ?
Can you share it with me to ensure that we both in the same channel.
Wincent_Intel
manu-solystic
Hi
Thanks for your answer
So I am using a cyclone 10GX    FPGA   10CX085YF672E6G   on my design
And i want to test the PCI express on my design
I use the folowing Intel Example
1) - Cyclone 10 GX - PCIe Gen1 x1 Avl-ST
2) - Cyclone 10 GX - CvP Initialization Design Example
Theses design does not work on my board,
Clk_usr   (pin AC13) is not connected on my design, and i cannot connect any signals on this pin,
Because this pin is not accessible (no via, or pin_escape to access for this pin)
So I want to know
Do i need  the clk_usr    for the pci express   HIP,
Can I use  another clock already connected on my degin
On my design I have a 25Mhz clock, and a 100Mhz Clock,
I ask if there is any way to use pci express without clk_usr, by using an internal connexion clock into the FPGA
Because the pin clkusr  AC13 is not accessible
Attached my design, for PCI express testing    compiled with Quartus pro  22.3
thanks for your help ..
regards
regards
FvM
Pin connection guidelines clearly state:
"This pin is used as the clock for transceiver calibration, and is a mandatory requirement when using transceivers".
manu-solystic
So Thanks
So i saw this item, but too late,  on my board, this pin is not connected,
So i Ask here , if there is a way to route another clock to this signals
If I can check the PCI express, on my board, without this pin
We plan to reroute this board, with this clock connected,
but what i want is to check the PCI express on my prototype board
regards
Wincent_Altera
Can you please try the clock call "AA6" ?
It is quite similar with AC13.
Detail please refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-10/10cx085.pdf
Wincent_Intel
manu-solystic
But the AA6 pin if for 484 pin FBGA  Cyclone 10  GX
On my design I have a 672  Pins FBGA , and the AA6  is  the TRST signals
I do not know if it's working on a 672 pins FBGA
Wincent_Altera
Thanks for your shift response.
I dont see any other option of clock user other than that.
Perhaps you can take a try and see if it is workable or not. Let me know your finding.
Looking forward to hear back from you.
Wincent_Intel
Wincent_Altera
Also there is an extra notes for your information in
https://www.intel.com/content/www/us/en/docs/programmable/683417/current/transceiver-pins.html
Other than those two pins, I don't see any alternative pin to perform it.
Also, Intel does not test on the function of other pins that can perform a similar function in any historical test.
Wincent_Intel
Wincent_Altera
We wouldn't advise turning off the CLKUSR clock. In my view the FPGA device won't be expecting this to happen.
The CYclone 10 PCG states on page 19 :
Hope this clarified,
Wincent_Intel
Wincent_Altera
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
manu-solystic
regards
Wincent_Altera
Hi
Thanks for your understanding.
With that said, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
