FPGA Intellectual Property
6673 Discussions
Cyclone V Reconfigurable PLL
I am attempting to use a reconfigurable PLL in a Cyclone V. I am using two routes – ModelSim Starter as provided with Intel FPGA toolset(Ver 16.1) and a full blown version of Modelsim (10.5a). I am having issues with both routes at the moment:
1. ModelSim Starter 10.5b
# Loading rtl_lib.cpu_pll_0002
# ** Fatal: Bad library format, library not compiled with Intel FPGA Edition compiler.
# Time: 0 ps Iteration: 0 Instance: /sys_clk_gen_tb/uut/cpu_pll_inst/cpu_pll_inst File: D:/Sandbox/Projects/TJ6394/Firmware/V1.0/Altera_IP/CPU_PLL/cpu_pll/cpu_pll_0002.v
# FATAL ERROR while loading design
# Error loading design
This error occurs despite deleting the library and recompiling to give me a clean build.
2. ModelSim 10.5a
# Loading C:/intelFPGA/16.1/quartus/eda/sim_lib/verilog/altera_lnsim.altera_cyclonev_pll
# ** Error: (vsim-3033) C:/intelFPGA/16.1/quartus/eda/sim_lib/altera_lnsim.sv(27862): Instantiation of 'cyclonev_ffpll_reconfig' failed. The design unit was not found.
# Time: 0 ns Iteration: 0 Instance: /sys_clk_gen_tb/uut/sys_pll_inst/system_pll_inst/altera_pll_i/genblk2/genblk2/cyclonev_pll File: C:/intelFPGA/16.1/quartus/eda/sim_lib/altera_lnsim.sv
# Searched libraries:
# C:/intelFPGA/16.1/quartus/eda/sim_lib/verilog/altera_lnsim
# C:/intelFPGA/16.1/quartus/eda/sim_lib/verilog/cyclonev_ver
# D:/Sandbox/Projects/TJ6394/Firmware/V1.0/Modules/sys_clk_gen/V1.0/Implementation/sim/modelsim/rtl_lib
# Loading work.altera_pll_reconfig_core
# Loading work.altera_std_synchronizer
# Loading work.dyn_phase_shift
# Loading work.generic_lcell_comb
# Loading work.self_reset
# Loading work.dprio_mux
# Loading work.fpll_dprio_init
I assume I am missing a library but I am not sure which one- I have manually compiled all the cyclone v libraries but I cannot see any reference to the missing design unit in any of these libraries.
Anyone got any suggestions.....
I met the same problem just now... I'll try 15.1 ...
Did you find a solution? I got stuck in the same problem :(
