FPGA Intellectual Property
6669 Discussions
DDR HP Controller, writes changes behaviour
I upgraded a design from the native controller to the native HP controller.
It works from 10 min to half a day, but suddenly the writes change behavior.
Correct operation:
Write goes high and stay there for several pages.
Write_data_req goes high and stays there until a page change is performed, then it goes back on. I use this to control a fifo. So I am able of bursting data at full clock speed. (with the exception of the page changes).
Suddenly the write data reqest starts to accepts burst of 8. It stays high for 8 beats, then it goes low for 5 beats, and back on. I keep write asserted the whole time.
The data is clocked in using a fifo, and the result is that I have to multiple the fifo size.
Not ideal..
I cannot find any changes in the phy/dll tracking using STap.
Has anyone seen this behaviour before?
I am using a 16bit DDR from micron, running at 100MHz.
Full data rate.
apus
