FPGA Intellectual Property
6670 Discussions
Nios2 Embedded Evaluation Kit(NEEK)
Hi all!
I am University student. I am studying Nios2 system.
I did download neek_standard_ddr_vga_mirror_design_example.zip at http://nioswiki.jot.com/wikihome/vgaapplic...selectorupdater.
It is correct Cyclone III starter Kit + Nios II Embedded Evaluation Kit(NEEK).
But i haven't Cyclone III starter Kit. So I try to modify CycloneIII development kit + Nios II Embedded Evaluation Kit(NEEK).
In Quartus, i meet problem at Compilation.
The error message is
Error: IP Generator Error: C:/altera/kits/NEEK/neek_standard_ddr_vga_mirror_design_example/ip/neek_ddr_lcd_capture_dma/neek_ddr_lcd_capture_dma.cpp:74:8: Variable endOfPacket is not properly initialised
Error: Can't elaborate user hierarchy "cycloneIII_embedded_evaluation_kit_standard_sopc:cycloneIII_embedded_evalua
tion_kit_standard_sopc_instance|neek_ddr_lcd_capture_dma_inst:the_neek_ddr_lcd_c
apture_dma_inst|neek_ddr_lcd_capture_dma:instance"
Please help me!
PS : I am Korean. So my English is poor.
I think you use v8.0 Quarus II, but the component in the example design is for v7.2. Try to use v7.2spx Quartus II to comile the design.
Thank you!!
Quartus 7.2 is generated neek_ddr_lcd_capture_dma ip.
But i meet another error.
In nios2 IDE, i executed "Run as nios II hardware"
Reading System ID at address 0x0C001340: Verified
Initializing CPU cache ( if present)
OK
Downloading 00000000 ( 0%)
Downloading 00100000 (89%)
Downloading 0B000020 (99%)
Downloaded 72KB in 0.8s (90.0KB/s)
Verifying 00000000 ( 0%)
Verifying failed between address 0x0 and 0xFFFF
Leaving target processor paused
Does this message say what?
It says either memory or memory controller you use for your program code is not functioning correctly.
