FPGA Intellectual Property
Annonces
6673 Discussions
DDR Timing violations
kwkprd
Débutant
3 320 Visites
Timing violation in task:- Report DDR timing analyzer
setup hold
   Address/Command (Fast 900mV 0C Model) | 0.18 0.18
  Core (Fast 900mV 0C Model) | 1.391 0.012
  Core Recovery/Removal (Fast 900mV 0C Model) | 1.555 0.197
  DQS Gating (Fast 900mV 0C Model) | 0.147 0.147
  Read Capture (Fast 900mV 0C Model) | -0.019 -0.019
  Write (Fast 900mV 0C Model) | 0.023 0.023
  Write Levelling (Fast 900mV 0C Model) | 0.132 0.132
 *DDR Timing requirements not met.
The resolution from intel forum :
Resolution
"To work around this issue, please double check all the board skew settings in the MegaWizard or Qsys GUI to make sure all the parameters comply with the Altera recommended layout guidelines."
 i have checked all the board skew and ip settings in the design.
From tool am not getting any timing closure recommendations & summery is empty. how to solve this issue?
Violation i got in analyzer tool:-          -0.193 PCIe_X8_SUB_SYSTEM|emif_1|emif_1|ecc_core|core|ecc|io_hmc_ecc_inst|int_master_wr_data_info[2]
PCIe_X8_SUB_SYSTEM|mm_interconnect_0|agent_pipeline_002|gen_inst[0].core|data1[102]
0 Compliments
10 Réponses
sstrell
Contributeur émérite III
3 279 Visites
What device?  What Quartus version?  What are your settings in the parameter editor?  Way more info needed here.
0 Compliments
kwkprd
Débutant
3 251 Visites
Thanks for your Reply
I have attached the document for your quick reference.
0 Compliments
AdzimZM_Intel
Employé
3 230 Visites
Can you provide the memory datasheet as well?
What is the memory frequency? Can provide the General tab as well?
Adzim
0 Compliments
kwkprd
Débutant
3 215 Visites
General tab
datasheet:- MTA72ASS8G72LZ – 64GB
0 Compliments
AdzimZM_Intel
Employé
3 194 Visites
I have replicated the issue at my end and I can see the Read Capture timing violation with your EMIF IP setting.
I may suggest to use faster memory component that compatible with your memory device.
From my end, I have used memory speed bin -3200 parameter setting and running at 1066.667MHz clock frequency.
The timing is clean after running the compilation.
I hope you can get a same result as well.
Adzim
0 Compliments
kwkprd
Débutant
3 152 Visites
Thanks for your reply
I have made changes as suggested.
but got different violation
 older violation message
0 Compliments
AdzimZM_Intel
Employé
3 098 Visites
Are you using an Design Example generated from Quartus? Is there any other IP in the design?
What are the changes that you have made? It is possible that you share the changes again?
Adzim
0 Compliments
AdzimZM_Intel
Employé
3 010 Visites
Is there any feedback in this thread?
Adzim
0 Compliments
kwkprd
Débutant
2 983 Visites
 consider your suggestion i will try once again after my design updates.
as per this issue concerned i guess it will work after the updates.
Thanks for supporting.
0 Compliments
AdzimZM_Intel
Employé
2 881 Visites
Thank you for the feedback.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
0 Compliments
Répondre
