FPGA Intellectual Property
6659 Discussions
DDR address generating
Hi, everybody~~~
Will you please give me some advice on how to generate the DDR2 addresses in a better way. And I need to storage data in two different fifos into the DDR2, so I have to fetch fifo data alternatelly. But I don't have good idea that how to generate the address, and the following code is my test code. Thank you for your advice~~~
always@( posedge clk or negedge rst_n)
begin
if( !rst_n)
col_addr <= 10'd0;
else if( local_ready==1 && wfifo1_read_req )
begin
if( wfifo1_ca_r == {10{1'b1}})
wfifo1_ca_r <= 10'b0;
else
wfifo1_ca_r <= wfifo1_ca_r + 1;
col_addr <= wfifo1_ca_r;
end
else if( local_ready && wfifo2_read_req )
begin
if( wfifo2_ca_r == {10{1'b1}})
wfifo2_ca_r <= 10'b0;
else
wfifo2_ca_r <= wfifo2_ca_r +1;
col_addr <= wfifo2_ca_r;
end
else if ( local_ready && rfifo_write_req )
begin
if( )
end
end
Thanks a lot~~
