FPGA Intellectual Property
6669 Discussions
DDR2 High Performance Con V7.1 SDC file difference between Stratix III and Stratix II
Hi
I create a DDR2 High Performance Controller V7.1 with a stratix II device and find that the auto-generated SDC file include many constraints, such as DQ/DQS/Addr/Cmd output delay, DQ input delay, clock max delay, false path,etc. But When I create the same controller with a stratix III device, the auto-generated SDC file doesn't include DQ/DQS output delay, DQ input delay, clock max delay. It only includes Addr/Cmd output delay and less false paths. I have two questions:
1. Why there are so many differences between stratix II and stratix III?
2. Should I add the DQ/DQS output delay and DQ input delay and the others into SDC file when I use TimeQuest to analyze timing with DDR2 High Performance Controller in stratix III?
If someone knows about it, please tell me.
Sorry, I can give you my advice, because I use Stratix II only.
But I think you are profession in my issues, I need your help.
I have some troubles with my design. I use MegaWizard in Quartus's Web edition(not create High performance Controller), to create ALTMEMPHY. It releases many files such as:
*_alt_mem_phy_reconfig_sii
*_alt_mem_phy_ sii
alt_mem_phy_defines
alt_mem_phy_sequencer.vhd
*_altmem_phy_sequencer_wrapper.vo
Module "alt_mem_phy_sequencer.vhd" is encrypted, so I can't see anything. How can I use this module?
To ensure my logic is ok, I simulate them with my logic by using NCverilog 5.5. But the way ALTMEMPHY tool uses parameter is new to me. And when I run my simulation, it can not stop and print out may warnings. So you can give me your advice.
I'm very impressed by ALTMEMPHY but I can't use it for a long time.
Thank you in advance!
--- Quote Start ---
Hi
--- Quote End ---
HI shsong ,
can you provide your ddr2 controller sdc file for reference?
regards
--sampath
