FPGA Intellectual Property
6670 Discussions
DDR3_CONTROLLER problem
There is an error when I complie the DDR3 controller simulation design:
Error (17044): Illegal connection found on I/O input buffer primitive DDR3_example_sim_e0:e0|DDR3_example_sim_e0_if0:if0|DDR3_example_sim_e0_if0_p0:p0|DDR3_example_sim_e0_if0_p0_acv_hard_memphy:umemphy|DDR3_example_sim_e0_if0_p0_acv_hard_io_pads:uio_pads|DDR3_example_sim_e0_if0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|strobe_in. Source IO DDR3_example_sim_e0:e0|DDR3_example_sim_e0_if0:if0|DDR3_example_sim_e0_if0_p0:p0|DDR3_example_sim_e0_if0_p0_acv_hard_memphy:umemphy|DDR3_example_sim_e0_if0_p0_acv_hard_io_pads:uio_pads|DDR3_example_sim_e0_if0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|obuf_os_0 also drives out to other destination than the buffer.
The error points to the following code:
if (DIFFERENTIAL_CAPTURE_STROBE == "true")
begin
cyclonev_io_ibuf
.differential_mode(DIFFERENTIAL_CAPTURE_STROBE),
.bus_hold("false")
) strobe_in (
.i(capture_strobe_ibuf_i),
.ibar(capture_strobe_ibuf_ibar),
.o(dqsin),
.dynamicterminationcontrol(1'b0)
end
else
begin
cyclonev_io_ibuf
.bus_hold("false")
) strobe_in (
.o(dqsin),
.ibar(),
end
Have anyone meet this error before?
Are you sure the dynamic control should be ground? If you did not chane it, then ok
Next thing, the error means that component there, is making an illegal conection, perhaps it is bidirectional and it is connected to something unidirectional outside. Perhaps it is connected to the wrong type of pin, perhaps it is connected to multiple pins outside on your top level (note that the second error says it "also drives out other destination than the buffer").
Here is the help saying what that means:
http://quartushelp.altera.com/13.1/mergedprojects/msgs/msgs/escl_scl_illegal_wys_io_ibuf.htm
Perhaps one of these gives you a hint, someone had this on a Stratix IV part:
http://www.alteraforum.com/forum/showthread.php?t=5825
